Strange light at all OIII antlia 3nm filter
9 replies557 views
Taras_M avatar
Hi everybody,
Id like to ask here about strange behavior of my Pelican Nebula imaging.
Last night Ive get on all of my OIII images this strange scattered (?) light.
Could anyone tell me, what it can be?
thank you and CS!
Themis Karteris avatar
Type of filter? unmounted?
Scattered light from a bright star off-field, most likely.
Taras_M avatar
Themis Karteris:
1.25 Antlia 3nm V-Pro mounted
Bruce Donzanti avatar
I agree with Andrea.  I get these now and then on both my refractor and SCT.  It is usually reflective light from a very large, close by star.  Sometimes, it can be from a local light source.  And I have the Antlia 3nm V-Pro mounted filters but it also happens with my Chroma filters.
Taras_M avatar
It’s very strange to me, because the same region with Ha filter (also antlia 3 nm) shows no reflections at all…
Thomas W avatar
That stray light points almost perfectly in the direction of... Deneb!
At magnitude 1 spectral type A2, it's both bright and blue. Flux from Deneb and camera QE are both greater at OIII compared to Ha, hence the difference between the frames. Small changes in pointing or a meridian flip could also result in the differences. What could be happening is light from Deneb is landing on some surface and reflected onto the sensor - it's a common issue most people will run into at some point. Sometimes this can be fixed by shining a bright light down the OTA then using baffling / masks / flocking material, though the success will be dependant on the exact opto-mechanics of your system.
Christian Koll avatar
Taras,
as others have pointed out, this is stray light from your optical train and has nothing to do with the filters.
To check for glossy surfaces in your optical train, just point the telescope at a bright surface (white wall), remove the camera and peek through the draw tube.
Any reflecting surfaces will be visible.
Often, those black anodized aluminium spacer rings (to adjust backfocus with) are the culprit - these have a reflecting surface (even if threaded inside).
Having had the same problem, I removed the anodized finish and coated mine with Noctutec matte black lacquer. This solved the issue.
Noctutec is a German brand, I'm sure there is similar stuff available from astronomy stores from where you live.
These straylight reflections mainly occur in the green filter, a little in the blue and almost not in the red.
This depends on the properties of the reflecting surface within your optical train.
Again, this has nothing to do with a particular filter brand or filters at all.
Chris
Taras_M avatar
Christian Koll:
Taras,
Chris
Thanks to all who replied me. Strange to me is still that even if Im pixel exact at the target, Ill get this only through my OIII filter, but nothing to see through my Ha filter.
CS!
Michael Hornfeck avatar
CS!
A quick google search of Deneb's spectrum shows that it outputs very little light at the Hα wavelength, and is almost entirely centered on OIII. It's a blue-white supergiant that's no longer fusing hydrogen so I imagine that's why there isn't any visible light in hydrogen alpha.
