How to identify "seeing"?
12 replies743 views
Sascha Wyss avatar
In my recent video about the new tool of RC Astro I talked about seeing and to use the MeteoBlue website  to identify your own local seeing conditions. I got a lot of feedback which stated that the values published by MeteoBlue were inaccurate. Now my question:
What is the best way to identify/look up/analyze the seeing conditions before/while shooting and after the shot  based on your experience?
Scott Badger avatar
There’s always the star twinkle factor….though my stars always twinkle. Maybe cuz my seeing always sucks!…ha! I’ve had the same experience with MB so I never really know until the first auto-focus run. And then it can double or halve in an hours time…. Meteorically, it’s not so much about air movement but dynamic thermic conditions. Wind can sometimes even help by keeping things mixed but then is it’s own problem without an observatory.
Scott
Wei-Hao Wang avatar
First you need to understand your instrument well.  Then measure the star FWHM of every image you took.  The FWHM is determined by both your instrument (optical aberration, diffraction, and tracking error) and seeing.  Taking out the instrumental part, you are left with seeing.
Scott Badger avatar
Wei-Hao Wang:
This is where discussions of seeing can be confusing. There is the potential seeing based on meteorological conditions that MB purports to show, and then there's the resolution we each can realize of that potential with our own equipment, but when seeing conditions are talked about, I'm never sure which is meant. Note that there are also other seeing factors neither meteorological, nor mechanical, like imaging a target that happens to be just above a warm house on a cold night.... Anyhow, as Wei-Hao Wang said, over time you establish what your own very best fwhm is, and then your current seeing is measured off that based on images taken. The challenge then is determining if gear is optimized (best focus, collimation, backfocus, etc.) or if there's anything you can do to close the gap between potential and realized, and more challenging when there isn't any accurate current seeing conditions report to reference.
Seeing can also change dramatically through the night, so if I get started and find it's not worth imaging (about 75% of the time during the winter), I'll leave everything set up and then get up periodically to check if it's improved.
Scott
Mina B. avatar
I get a FWHM on a single sub on my doublet ED of around 2.3" most nights near the zenith, which I consider fairly decent - I have a fair bit of chromatic aberration, I use a ZWO asi 183mc pro. With better optics and mono camera, it'd be lower. My guiding is half of my image scale - around 0.5-0.55" rms total.
meteoblue gives me seeing values around 1.5 arcsecs mostly - which I'd consider decent. I'd say it's fairly correct in my case.
Joe Linington avatar
My seeing is so bad and variable, I use my guiding as an indicator. If my guiding is below 0.65 and steady then it’s a great night and try to optimize everything. Between 0.7 and 1, keep imaging. Seeing is between 2 & 2.5. Above 1, I switch to bigger pixels or go to bed. For me , the guider is the simplest system to get optimized and doesn’t change much so it is a reliable indicator that is constant between different equipment combos. I also monitor my average ADU. This doesn’t give me an absolute repeatable reference like guiding but does give me an indication of the changes through the night.
Bray Falls avatar
Quantitatively it is difficult to know unless you own a seeing monitor. Otherwise you must make guesses about it based on the FWHM of your own stars, or by actually observing an airy disc and using the Pickering scale. The star FWHM can be valid if your system has high resolution, where the difference in 1" and 2" seeing is plainly obvious.
A good way to know when its good visually could show as your guiding being weirdly accurate, or the stars above do not twinkle. On nights of sub 1" seeing the 16" RCOS I operate goes from guiding at 0.5"-0.6" to 0.3"-0.4".
You could also make guesses about it based on the jetstream speed.
Wei-Hao Wang avatar
BTW, I don't think we can predict seeing as well as we predict temperature, wind, and precipitation. Seeing is a much more complicated and more poorly understood. It's also highly related to microclimate in your neighborhood, which cannot be included in the large-scale model used by systems like meteoblue.  So I never take meteorblue's seeing forecast seriously.
Bray Falls avatar
Wei-Hao Wang:
I concur with this big time. The fluid nature of the atmosphere closest to the ground has a huge huge impact on your seeing. This is something that professional observatories study extensively when planning a building. They will even consider things as small as how the turbulent wake of one building will impact one downwind, and plan the telescope locations accordingly.
Shameless plug I talk about this at length in this video (https://www.youtube.com/watch?v=0WjQFb2qCVE&t=1271s&ab_channel=BrayFalls)
Scott Badger avatar
In my experience, it’s thermal turbulence much more than air movement, which is why wind can sometimes actually help. A couple weeks ago I was imaging in gusts up to 25mph+ and guiding sub 0.7”. FWHM’s we’re in the mid to high 2’s, but low 2’s is the best I ever get. This winter I had many calm nights and seeing so bad ASTAP couldn’t plate solve Another correlation I saw very consistently this winter (when seeing is worst, generally) is if it was clear all night, the seeing was terrible, and if the seeing was decent at the start, I could count on two hours at best before the clouds arrived. Though, maybe that’s just the Murphy factor…..
Scott
Keith Egger avatar
I notice Sharpcap has a “Seeing Monitor”. I’ve never used it - does anyone have experience as to how it works?
Scott Badger avatar
I haven’t used it either, but maybe it monitors FWHM variability and that way doesn’t have to take into account local factors, like environmental and equipment, or change in focus?
Scott
Christian Koll avatar
Grüezi Wohl Sascha,
I also believe that your FWHM / MTF numbers in your acquisition software are an indicator for your current seeing (given you don't shoot low in the sky), but deriving particular numbers would be hard.
I also use Meteoblue to check for weather conditions, but the seeing numbers provided there ar nothing more than an indicator if the atmosphere will be rather calm or not.
I am puzzled you didn't know Meteoblue - it's a Swiss company from Basel! smile
Greetings from neighbouring Austria - keep up the good work!
Chris
