Focusing Using a Tri-Bahtinov Mask
14 replies437 views
Jerry Gerber avatar
Hey all,
When I use a tri-bahtinov mask with my 4" or 6" refractor, it's hard to see the diffraction spikes unless 1) the sky is fully dark and 2) I am focused on a big, bright star.  Unless these two criterion are met, I can's see the spikes.
Am I missing something here in terms of my technique using this focusing mask?
Jerry
Robert Gillette avatar
Try increasing the exposure time and use 2x2 binning. Even with RGB filters, 10-15 seconds should be sufficient.  A mag 3 star should do the trick.
CS, Bob
Jerry Gerber avatar
CS, Bob
Thanks Bob, I've tried 10" exposures with an L-Pro filter, with 2:2 binning.  It helps, but I still have to hunt for a bright star to see the spikes.  If I zoom in I can see more stars with spikes but then the resolution suffers and it defeats the purpose of having sharp spikes to use for focusing..
Dave Rust avatar
B-masks made of clear plastic usually display significantly brighter spikes than the black plastic masks, I've found.
Well Written Concise
Jerry Gerber avatar
Dave Rust:
Thanks Dave, that's good to know.  Might you know who sells clear plastic masks?  I've been able to only find black ones.
Jerry
Rob Foster avatar
Hi Jerry, remind me what imaging capture software you use? In NINA , I slew to a brighter star in the quadrant of target, though usually before fully  dark.  I’ll zoom in on the star then loop  at 2 sec exposures but at a significantly higher ISO or gain.  I have found I don’t need the brightest star to achieve good diffraction spikes.  Good suggestion on the 2:2 binning…. I’ll have to try that.
Jerry Gerber avatar
Rob Foster:
Hi Rob, hope all is well!  I use ASIAIR Plus with an Android tablet.  I've been trying 2:2 and even 3:3 binning with 5" or even 10" exposures, but the only way I can see the spikes is to zoom way in--but then the resolution begins to suffer and the spikes are not sharp.  The spikes don't show up with the smaller, less bright stars.  It seems the brighter the star the easier it is to see all the spikes and get to sharp focus.
Nick Grundy avatar
Jerry, i've got a simple adjustable one that's laser cut from some sort of stiff composite cardboardy crap. It works on the 130PHQ though. the trick is getting a decent star. I assume you've already polar aligned when you are focusing the main scope?
It looks like the weather is going to give you a few days to sort this out. If you are in a pinch you are welcome to borrow mine if you drive up this way. I never use it with the EAF installed.
Concise Supportive
Dave Rust avatar
Jerry
regarding clear plastic masks:
williams optics makes them, but they are for their specific diameter scopes (but one could fit yours).
I got mine on Etsy believe it or not. Go to Etsy.com and do a search. Several will show up.
Ebay has masks, but I didn’t see any clear ones today.
Dave Rust avatar
Oops, I’m wrong. William Optics makes masks for any scope now.
Richard avatar
As noted by Dave, William Optics make bahtinov masks which are integrated into a dust cap but also sell adjustable masks which can fit a range of dew shield sizes. Here's some of the adjustable types:
https://www.firstlightoptics.com/search/for/Bahtinov/
Jerry Gerber avatar
Nick Grundy:
Thanks Nick, I've got the tri-bahtinov mask for the 130PHQ but I think I need to learn how to use it better by increasing exposure.  I usually focus before I polar align so that ASIAIR Plus plate solves successfully the first time, making PA faster.
I'm going to send you a PM about going to Stonyford...
Jerry Gerber avatar
Richard:
Thanks Dave and Richard,
I'll check out what Williams Optics makes.
It looks like they make one that might fit on my 4" and 5" refractors, but nobody has them in stock..
Jerry Gerber avatar
Richard:
I just purchased the Williams Optics focusing mask.  It makes sense that being made of clear plastic it's going to transmit light and the diffraction spikes better than black masks.  I think it will  help.
Richard avatar
Jerry Gerber:
Richard:
Awesome. I have a Redcat 51 and FLT120 which have the integrated bahtinov mask in their dust cap covers. I've always used an auto focuser so I use the bahtinov mask just to get initial focus and let the auto focus routine run throughout the night. I would intentionally choose a brighter star near my imaging target for initial focus then slew to my target for imaging.
In a Bortle 5 zone with a OSC, I can usually usually take a 5s sub to get decent diffraction spikes. Using a 4.5nm narrowband filter with my monochrome camera or the l-extreme filter with OSC, I aim for 5-10s and bin 2x2.
