Jerry Gerber avatar
Hi there all,
I'm using the PE200 pier extension for the TC-40 tripod and the AM5 mount.  Last night when M101 began its transit, the camera on the end of my 5" refractor brushed up against the tripod leg.
Would a pier, instead of a tripod, help with this issue?  Hopefully a carbon-fiber pier that I could attach the PE200 and the AM5 to.  Anything like this on the market?
Thanks,
Jerry
James (Jim) Poulette avatar
When things get "questionable" - I have 2 of the PE160 piers that I stack. It may or may not be an option in your case.
Good luck ! smile
Gilmour Dickson avatar
I have never heard of a carbon fiber pier. And to be honest I don't see a need for that material choice for something that is designed to be as rigid as possible and permanently installed.  My material choice for my pier was about 50 bucks of scrap steel and cement. If you mean a "portable" pier like the iOptron, I still cannot imagine CF as a material choice. And if it were, the price would no doubt be insane.
Nick Grundy avatar
I've actually got a mini-pier on top of my HEM44 mount for this reason. I need a bit more clearance from the carbon fiber tripod. The mini pier is metal, while the mount is CF. It's not logical but it works and it's solid.
ZWO has the same equivalent for the AM5 https://astronomy-imaging-camera.com/product/zwo-pier-extension-160mm-for-am5-mount/
maybe this would help?
Jerry Gerber avatar
I've decided to look into buying a tri-pier for the AM5 mount.  Anybody have one that they can recommend?   My TC-40 tripod isn't cutting it with the Askar 130PHQ scope.  The AM5 handles it perfectly, but the telescope with camera is a bit too long to image at the meridian and zenith without bumping into a tripod leg. Please let me know if there's a tri-pier that has an adapter for the AM5. Thanks!Jerry
Can't achieve focus on Lunt 50 with 2x Powermate
Hi, folks. I have a Lunt 50 with 600 BF and Saturn-M SQR camera. It works a treat. I've tried attaching my Televue 2x Powermate (2" version) but cannot achieve focus. It seems I need to be closer in than I can manage. I have read that the 50...
Not relevant - focuses on focus issues with solar telescope, unrelated to pier/tripod collision problem.
Oct 10, 2024
