I was hoping someone knows a solution to the following issue I am having:
I recently put together a new rig; which includes a ZWO EAF motor focus and runs on NINA 2.1.
When I initially set up all the equipment in NINA, I had the focuser in its "zero" position, and thus also set the EAF to zero, as per the NINA configuration dialog for the EAF.
However, everytime I boot up the system, the EAF insits on being at "0", even though it is actually at the focus position (or thereabouts).
The only solution appears to be to loosen the EAF coupling, actually set the focuser to zero and re-tighten the EAF coupling.
Obviously, that is not a satisfactory solution.
Any ideas what could be going on here?
Marc
Marc
