Vin avatar
Hello,
I'm wondering if anyone has ever had a problem with flats calibration with long focal length Mak imaging.
I'm testing out a new setup  (details & example here: https://astrob.in/ij748l/0/) and for the life of me I cannot understand what is going on with the flats.
I'm using the exact same process as w a wide field refractor (calibrating in EKOS for about 23000 ADU, using APP to calibrate and stack) - with the wide-field this never happens.  Are long deep images more sensitive to autofocus change complicating flats calibration?  Or am I just being stupid and missing something obvious?
All help would be appreciated because this would make a nice galaxy imaging unit if I can get this sorted.
Thanks,
Vin
Your master flat is wrong on many levels so you might want to revise how you take them. Nothing wrong with a long focus Mak in itself since I never ever had any issue with them and if anything a narrow FOV helps get it right.
I would, however, reconsider the wisdom of shooting for M101, a rather dim galaxy, at those pixel scales with a 5" reflector for just 3 hours of integration but to each his/her/their own.
Vin avatar
Thanks Andrea.  Yes I hope it's just that I need to figure out a new flats process.  I'm using the same light panel as I do for my 4" f5 refractor and the same camera so I assumed it would work here.  But clearly it's not!
I just picked M101 as a handy target near the zenith (I have restricted FOV) and wanted an object with enough structure in the FOV to see if the image would work.  You're right about the dimness - that in itself was a learning process (can you believe I even tried a dual band filter on M101 at one stage, hilarious).  And for sure 3h is no where near enough data, but the aim for this test was more just to see if the guiding and the mount would handle the focal length, and whether the camera would vignette.
I think I will try sky flats next time we ever have clear skies again here.
Cheers - its good to know that its just user-error rather than something fundamental about the setup b/c that gives me hope for some deep targets!
Narrowband Exposure Lengths vs. Swamping Read Noise ... help!
Can someone help me out here a little. It's my understanding that you want to square your read-noise at the gain you're shooting at and then multiply it by a swamp factor then convert that to ADU units and then add that to the median ADU valu...
Read noise considerations relevant to flat calibration sensitivity issues.
Nov 6, 2024
Artifact in the picture but not in the flat frames.
Hi everyone, While taking pictures, I noticed a strange artifact on the subs. Blue circle with a green border. It was also visible after the meridian flip, but it moved from the position in the image compared to the before the flip. I noticed that I ...
Artifacts in images versus flat frames directly addresses calibration problems.
Dec 28, 2024
Deep Sky Stacker not working
Hi All, need some help with DSS. I have been using it for 3 years but today I am totally lost. I took 66 images in HA last nite, stacked today in both 32bit and 64 bit and every time I am getting an image of a different star field…its operating...
Flats calibration problems could explain misaligned star fields in stacked images.
Sep 20, 2021
