Stacking in APP + Color Calibration in PI SPCC leads to green cast - any help?
1 reply139 views
Christian Koll avatar
Hello!
I used to stack my images in Astro Pixel Processor (APP) and then color-calibrate (SPCC) and deconvolve them (BlurXterminator) in Pixinsight.
Why stacking in APP? - Because I am used to it from before acquiring PI and I found it was much faster and more convenient that stacking in PI.
However, I found that the color calibration with SPCC did not produce propper results - I always get a greenish cast, especially noticeable in galaxy photos.
Referring to the SPCC manual, I figured out that this has something to do with the de-mosaicing algoritm for OSC-data (which is the case).
According to the manual, you should drizzle OSC-data (scale 1) and not use the VNG-debayer method. This works well when staking the data in PI (WBPP) and I get the correct colors after applying SPCC.
However, neither using the Bayer/Xtrans-debayering, nor a drizzle integration will fix this in APP.
The easiest solution will be stacking entirely in PI from now on, of course.
However, I have some old data where I only kept the APP-masters of the bias and flat frames - these are unuseable in PI.
So, restacking them in PI is not possible, unfortunately (I also don't have that OSC camera any more).
So if anybody has had the same issue and found a solution / setting in APP, please let me know, thanks!
Chris
You can always color calibrate in PI, just don't use SPCC (waste of effort if you ask me). To get started use only CC and see what happens. I never had any issue with color cast using the VNG algorithm, by the way.
[RCC] Help me improve my landscape astrophotography processing
Hi, since last summer, I have started doing landscape astrophotography more seriously and bought a new setup for this discipline. It consists of: Camera: Canon EOS 200da Lens: Samyang 12mm F/2.8 A stable tripod from SmallRig and a solid powerbank I a...
Discusses color calibration (RCC) in PixInsight for astrophotography processing workflows.
Mar 13, 2025
Anybody interested in processing an atypical M51 stack?
I'm getting my kicks by processing my images using my own Python programs. Not talking about processing skills, this means that the end results may not be as good as they could be if processed with better tools. I am thus very interested in seein...
Relevant — covers APP and PixInsight workflow integration.
Jul 23, 2021
[RCC] Leo Triplet in HaLRGB
I'm just getting started with mono imaging and the processing that goes into it and would appreciate feedback. Process: Stack and align with WBPPGraxpertStarXTerminator to remove the starsClone stamp to clean up the one dust mote that no amount o...
Addresses mono imaging stacking and PixInsight processing techniques for deep sky objects.
Mar 10, 2025
