Skywatcher 7ah powertank
1 reply•225 views
Abdul Thomas Jnr avatar
Hi guys. So my skywatcher 7ah power tank car plug adapter broke and decided to buy a replacement. Ive bought two now and none of them are unable to power my Geoptik flat field generator or my asiair pro. Also realised that the replacements i bought has a red dot on the side while the original that comes with the power bank does not. I need to buy one but unable to find the right one. Please help
Tommy Blomqvist avatar
Did you solve your problem?
When your are writing "red dot" I suspect you are refering to the LED - correct?
These cables doesn't convert the voltage and the most advanced part is the LED (that only indicates that you have power) and sometimes a fuse.
It is important that the other end has the correct plug (5,5x2,1 with positive tip).
