Ts Optics (or rebranded) maxfield 0.95 coma corrector
14 replies862 views
Dave B avatar
Hi is anyone using the Ts optics maxfield 0.95 corrector often rebranded Altair etc with an F5 8” Newtonian if so how do you find it and have you seen any reflections in your images caused by this corrector?
https://www.firstlightoptics.com/coma-correctors/ts-95x-maxfield-coma-corrector.html
Dave
D. Jung avatar
I'm using the TS version with my 6 inch F4 and am quite happy with it. It has some vignetting but easy to correct with flats. Correction of stars is really good (have used with with APSC size and smaller).
I haven't had any problems with reflections at all (only with cheap filters).
Can you find a better CC? Sure. Can you find worse ones, most definitely.
Dave B avatar
D. Jung:
Thanks  I found one comment where they had a reflection near bright stars with an F4 scope just wondering if anyone had come across this with their setup especially F5 (skywatcher 200pds).
wittinobi avatar
Dave B:
D. Jung:
Hallo Dave,
I have the "TS Maxfield 0,95x" in use with a SkyWatcher 130PDS and I have Reflections at some brighter stars.
I can see these Reflections on Pictures from D. Jung, too.
But I have not yet found a Comecorrector without this Issue.
With "GPU Comcorrector" you can find Threads with Reflection Issues, too.
Dave B avatar
Dave B:
D. Jung:
Hallo Dave,
Thanks for that i was hoping it would be better than the baader mk3 cc
Gianmarco Spagnoli avatar
Talking about reflections...
This is what i get with 0.95x coma corrector on Quattro 200p.
I didn't noticed the reflections untill was too late .
D. Jung avatar
That's not a reflection, that's a disaster 🤯
D. Jung:
I think the culprit is this star outside the FOV
Oscar H. avatar
Hi, I have the Sharpstar 0.95x (i.e the Maxfield)
It works very good for the most part
But, one time, (and this is strange, because it was only one time), I got that rainbow in the corner of my frame
it happened with my M63 image; it was nowhere near the galaxy, so I could just clone stamp it out of Starless, which was easy
but 90/95 percent of the time, it works completely fine; just remember to take flats, it helps a lot
and close any light leaks
Oscar H. avatar
SORRY
forgot to add a very important detail
I'm using a 533 sensor!
Can't believe I forgot to add that.
Probably most coma correctors work fine with that sort of sensor size.
Leonardo Priami avatar
Gianmarco Spagnoli:
These reflections are due to stray light from out field bright stars. So you can avoid this making a baffle in front of the tube.
Oscar H. avatar
Leonardo Priami:
Gianmarco Spagnoli:
thank you
baffle in front of the tube? can you elaborate? do you think M48 spacers added to the coma corrector (exposed glass end), would fix this problem?
Oskari Nikkinen avatar
This rainbow circle issue is well documented in the TS Maxfield 0.95x corrector. Had it in mine, not quite as catastrophic as here but very similar.
Have read that newer versions have fixed the issue, such as the sharpstar branded ones that started appearing some time ago. Mine was a 2020/2021 TS branded model and had this issue. With another corrector (Paracorr) i see no such rainbow with the same tube so safe to say the corrector was the issue. Flocking/baffling might help, but ultimately you want to get rid of this corrector to fix the problem for good.
Marcus avatar
I got the same issue with the Maxfield corrector. I do not see the rainbow circle on my further nebula projects, just at brigher galaxy projects. So I need a new one… maybe its also just a reason for a new telescope smile
Werner Stumpferl avatar
I have increadible reflexions with this CC together with an OAG and Filterwheel. I have inserted velour into the CC and painted all edges with Black Color. No essential change in reflexions. I changed to the Baader MPCC Mark III and all this problems are gone. Also vignetting is much smaller. Only disadvantage, the stars increase from 1.9 to 2.3" HFR.
Werner
Extreme asymmetry in diffraction spikes
Hi all, I just installed a primary mirror mask to hide the mirror clips as well as a CNC spider from backyard universe. Had about 10 mins of clear sky to test the result and am puzzled by the extreme asymmetry in the diffraction spikes as can be seen...
Author uses similar telescope setup; diffraction spike issues relevant to optics.
Feb 16, 2025
Dark Nebula
Hi! I work on my first dark nebula project, the Iris Nebula. I use my TS-Optics GSO Photon 8" F5 Newtonian Telescope with a coma corrector, ZWO ASI2600MC pro camera and the Optolong L-Quad filter. I got around 7h of data with 300s subs, in Bortl...
Author uses identical TS-Optics GSO 8" F5 Newtonian with coma corrector.
Mar 30, 2025
Reflections caused by EdgeHD or by the filters - do you have the same issues?
Hi there, this one goes out to users of the Celestron EdgeHD. I own my 8" one for some months now and in some of the images, I realized some reflections on bright stars in the LRGB data. I use a QHY294MM Pro and a set of Optolong NB filters as w...
Author specifically asks about reflections caused by correctors; directly addresses concern.
Sep 14, 2024
Problem with M54 extender and coma corrector.
I have a TSFMA360 focuser that I want to use with a TS 1.0x coma corrector for Newtonian telescopes, so that the corrector can be screwed into the focuser. I have an adapter to be able to screw it in.The problem is that, because the drawtube of the f...
Author uses TS coma corrector with Newtonian; similar equipment configuration.
Sep 16, 2024
