Jure Menart avatar
Hi all,
Right now I am always focusing only at the beginning of each session (my flow with KStars/Ekos is first 2-star alignment, plate solving, polar alignment, autofocus, start shooting, after shooting I take darks and in the morning I take flats/dark flats without changing optics of course). I forget about focus once I start the session (I know naive me) and just assume it remains the same.
I was thinking of enabling autofocus during the session (either triggered if focus decreases or just periodical focus) but I didn't integrated it yet to my process for two reasons:
- I was a little bit afraid it would go bad in the middle of session and I'd need to spend a lot of time to get focus back again (I had quite some issues at the beginning but after fixing it now I feel much more comfortable as I got really good and stable results lately)
- I don't know if it's OK to refocus and do flats in the morning only with latest focus
So my question is - what is your experience with re-focusing during session and then taking flats at the end (in the morning)? I assume the re-focusing is so small that it's not noticeable on flats? Is there any unwritten rule what is the tolerance which one could use which flats are still useful when focus changes?
I started to think about this question after stupid and sad story involved de-focusing during session yesterday, full story available here (yes yes I know, stupid me not to triple check before spending 3 hours ): https://www.astrobin.com/m78e9r/C/
Short answer: don't bother, whatever shift in focus you may end up with isn't going to affect the flats.
Jim Raskett avatar
Absolutely! Don’t bother!
As far as focusing during the session. My focus changes drastically some nights and very little on others.
Temperature variation is the reason and I autofocus (NINA Hocus Focus) at the beginning of the sequence and then every hour regardless of the temperature. There are other options besides time, such as HFD, or temperature change (if you use a temperature sensor.
Good luck!
Jim
Jure Menart avatar
Hi Andrea, Jim,
Thanks for your answer. Up to know I didn't enable it just as I wasn't sure about this but it's good to read that I shouldn't overthink this smile
I will enable it and just re-focus regularly from now on, it seems like the best solution especially if HW & SW is there to support it.
Jure
AstroBertUK avatar
Similar to Jim, I start the session by manually running the autofocus - this is to ensure that platesolving works OK. The NINA sequencer is then configured to autofocus after acquiring the specified target, and then automatically refocuses if the HFD changes by 10%. This, I believe ensures the best focus possible during the session.
Flats I will normally take either after the first manual autofocus, or at the end of the session. I'll also take them if I change filter.
NINA certainly helps with most of the 'hard' work smile
Jure Menart avatar
Thanks Bert!
Maybe I should start to think of buying the panel to take flats. For now I need to wait until the morning to do the white t-shirt flats smile It has been working quite good for me TBH. smile
AstroBertUK avatar
A panel certainly makes things easier - I bought this 'cheap' tracing panel from Amazon and never had a problem with it
Amazon Tracing Panel
Jim Raskett avatar
Thanks Bert for reminding me!
I also run an initial manually triggered autofocus to insure plate solving works ok for both polar alignment (TPPA) and initial target centering (plate solving) in the sequence.
Georg N. Nyman avatar
IMO, it is of absolutely no importance to keep a certain focus for aqcuiring flats…. important is only to have the same optical train for flats as for imaging…
Georg
John Hayes avatar
Jure,
The important thing is to A) achieve precise focus when you start and B) maintain precise focus throughout the night.  Then, when you take flats they will also be taken with the proper (precise) focus.  Your C8 has a temperature sensitivity of about +/- 1.3C before it goes out of focus enough to matter under roughly 1" seeing conditions.  That means that if you focus very precisely to the center of the critical focus zone, a temperature drift of only ~1.3C will pull the focus out of the CFZ.  If the ambient termperature of your site during the entire night is VERY stable, you don't need to refocus; but, that is rarely the case.  How often you need to refocus will depend on your site but in general, I would recommend refocusing every 30m - 40m with a C8.  I think that you should see a noticeable improvement in sharpness if you periodically refocus during the night.
Jure Menart avatar
Hi John,
thanks for very good description and woth real numbers for C8 - I am not that far yet (just installed autofocuser last month). I will take your advice and implement re-focusing every 30 minutes. Let's hope for nice weather soon to see this improvement smile
Thanks again and clear skies,
Jure
Respectful Supportive
The value of the CFZ is equal to 2*2.44*Lambda*F#^2, which with Lambda=0.55 um and F#=10 for a C8 (not reduced) yields a value of 0.268mm. This, if I am not mistaken, is the distance from best focus to cause a wavefront error of 1/4 Lambda. I strongly doubt that you need to be strict in a typical amateur seeing between 2" and 3" (and that is when it is good). Unless you want to spend a lot of time refocusing instead of imaging it would be a far better strategy to refocus only when your measure of best focus (typically HDF) changes by a fixed amount (most of us would settle at around 10%).
Helpful Insightful
John Hayes avatar
There are different ways to define the CFZ.  The one that you've given is a geometric definition that uses the size of the Airy disk, which can be simplified to be ~ 2.5(F/#)^2 (in microns) in visible light.  If you use the Rayleigh quarter-wave criteria, the CFZ is 4*lambda*(F/#)^2 or about 2(F/#)^2 (in microns) in the visible.  The Rayleigh criteria is great for a space telescope but as you pointed out, it's overly restrictive in the presence of seeing.  One thing to remember is that smaller telescopes with an aperture "about" the size of the Fried parameter are less sensitive to seeing than larger telescopes.  Even though most locations don't experience spectacular seeing, I favor using an optimistic, "best-case" assumption of 1" seeing, which is appropriate for either small telescopes (<10") or for really good sites.  In that case, the S-CFZ is determined geometrically from the seeing limited blur diameter.  Designing to 1" also provides some "head-room" so that things will work just fine even when the conditions are worse.
The really important thing is to know the temperature sensitivity of the optical system.  That's the change in temperature needed to shift the focus by half the full value of the CFZ.   Here is a chart that I put together a few years ago showing the computed values along with some published values for various telescope designs.  The disclaimer in yellow reflects the fact that these numbers are all computed from the design of the systems; not from measured data.  There may be other subtle effects in any particular system (such as loose fasteners, or poor bonding) that could cause problems.
Personally, I never experienced 1" long exposure seeing, even with a 1 mt scope in Chile's Acatama. But that is digressing. I shall only note that I use some of the configurations listed above and I never have to refocus as often as that table suggests. In fact, the telescope I need to refocus most often isn't a telescope at all, it's my Nikkor AF-S 300m lens @ f/2.8. But then it is every hour or so at most.
Miguel G. avatar
+1
Meade 6000 Series 70mm APO - Focus Jammed/Stuck
So I am still very new to imaging. I have been using a dslr for about a year and just got my ZWO ASI183mm pro a few weeks back. I took it out last week for the first time and got everything up and running with no issues. Last night was finally crysta...
Autofocusing and flat calibration procedures for astrophotography data collection.
Nov 6, 2021
Autofocus (Hocus Focus) standalone or in sequencer
Hi all, Did anybody else noticed the change in behavior when executed manually (from Imaging tab) or if it's triggered from sequencer? Very often I am having issues when executing autofocus from sequence at various stages. When I trigger it from ...
Discusses autofocus behavior during imaging sessions, directly relevant to author's focus strategy question.
Mar 5, 2025
Question regarding frequent Autofocusing: Isn't it just wasting a lot of time?
I do use an auto-focuser (Sesto Senso 2), but after the initial auto focus before any sequence, I don't. The reason is, because it takes forever. 10 minutes or more sometimes. It just keeps moving the focuser up to like 24 points until it finally...
Directly addresses autofocus strategies and frequency during imaging sessions.
Jul 23, 2021
Minimum exposure time?
Being in light polluted cities what is your bare minimum exposure time you will ha e for any given target. Just starting out and I have only been doing short sessions. I would assume the more pictures/exposure time the more data there is for better s...
Covers focusing and session workflow for astrophotography imaging.
May 16, 2021
Is this dew?
So, I have a really silly question; I ask because I am trying to not buy something I might not need. Over a few nights I've discovered my pictures end up being cloudy after a few hours. Being in Seattle, I just figured clouds moved in. Though I r...
Refocusing during sessions may prevent dew-induced image degradation.
Aug 19, 2021
