Collimation screws for the primary mirror - RC scope
5 replies523 views
IS_17m avatar
I have a RC scope. There are three pairs of these screws around the primary mirror (in the back of the telescope). I know that 3 screws are for adjusting the mirror position and the other 3 are for locking its position after adjustment.
I know that is "rare" that a primary needs to be adjusted on a RC scope, but I want to understand how it works the collimation with these screws, if I need to do it someday.
- the bigger screws are the ones for adjustment and the smaller screws are the locking ones, right?
- it is recommended to adjust ONE pair at a time, and avoid untightnening all the locking screws at the same time because that can mess up the focal lenght, correct?
The idea that I have (correct me if I'm wrong please) is that the procedure must be done in this order:
- untighten ONE lock screw
- adjust (tighten or untighten, depending on how much I want to adjust/move the mirror) the bigger screw of the SAME pair
- tighten the lock screw again of the first step
> move to the next pair
Thank you,
Clear Skies
Chris Jensen avatar
I dont have an RC scope, but this does appear to be a good tutorial. https://youtu.be/-iW_OmRDndk
Hope it helps
Ed Dixon avatar
My iOptron RC6 was brand new and still needed to be collimated with adjustments to both ends.
vercastro avatar
I think you're good to loosen all the locking screws at once by a bit then adjust the collimation screw. The collimation screw should hold on their own temporarily.
Having said that, this design looks different than what I'm used to (RC10 tube maybe?) and the mechanics might be slightly different.
Markus Gorski avatar
Hello,
only two pairs of screws should be used to collimate the primary mirror, and always the same ones. Otherwise there is a risk that the distance between the primary and secondary mirrors will change. This resulted in a maladjustment that is not so easy to eliminate.
Best regards!
Isabela Chase avatar
Hey there, I can totally understand your concern about adjusting the collimation screws on your RC scope. I am new to this forum, but I had a similar issue with my own telescope a while ago.
TS-Optics RC8 - Collimation : next step ?
Hi All, I received 2 weeks ago a TS Optics 8'' Ritchey Chretien, and tried to collimate it (out of the box, the stars were just horrible…. I plan to use it first with an AstroPhysics 0,67x telecompressor (reducer) to get more light and ...
RC scope primary mirror collimation screw adjustment.
Apr 3, 2021
Refractor collimation question
When i defocus, the center of the defocused stars are all shifted in the same direction across the field. If the primary cell was out of collimation, would the center of defocused stars be radially off center around the field? Or is this tilt? The pr...
Discusses primary mirror collimation issues and defocused star behavior.
Sep 11, 2024
RC10 Backfocus has moved since mirror cleaning and collimation
Hello eveyone, I have an Orion Steal Tube RC10 F/8. Last weekend I removed and cleaned the primary mirror. I reinstalled and collimated the mirror and snuck in a quick imaging session on Wednesday. I have modified the secondary mirror holder and it n...
Directly addresses RC telescope mirror cleaning, reinstallation, and collimation procedures.
Sep 14, 2024
First Light for Apertura Carbonstar 6" RC
A couple weeks ago I picked up an Apertura Carbonstar 6" RC from High Point Scientific. Here are my initial impressions. I bought this scope to give myself a bit more reach focal-length-wise for some of the smaller targets. It's native FL is...
Documents RC telescope setup and initial observations relevant to collimation.
Nov 2, 2024
