Switching Tablets During an Imaging Session
6 replies217 views
Jerry Gerber avatar
Hi!
The other night I was out imaging and my intention was to capture 100 subs.  But at around 85 subs my Android tablet was nearly out of power even though it began at 100% charge.
I have another tablet and I am wondering, what would be the process of swapping out tablets during a session?  Would I simply stop guiding and imaging with ASIAIR Plus close the app, and reopen it on the 2nd tablet, or will this cause issues?
Or, will I have to shut down ASIAIR Plus and then turn it back on with the fully charged tablet ready to connect?
Thanks,
Jerry
David Nozadze avatar
Hi Jerry,
I always use my Android app on my phone and iOS app on my MacBook during and switch between them frequently, while ASI Air is in Autorun mode. Very often I have both terminals logged in simultaneously. The switching does not affect or interrupt any processes, running on the ASI Air during the sessions.
D
CVZ_Astrophotography avatar
You can turn off your tablet and the ASIAIR still keeps going if you use autorun. So switching to another device should be possible
Brandon Tackett avatar
@Jerry Gerber
I have multiple setups running ASI airs. As previously mentioned, once you have started a imaging session or plan, the device will continue to run as instructed. I have done this numerous times from a tablet to my phone when the tablet ran out of batteries. Once I got uses to the software, I just run everything from my phone. Additionally, you can set the device to station mode and a it will connect to your local wifi (if in range) . If you are logged onto your "home" wifi with a tablet, computer, or phone you can then log on to the device or multiple ASI airs at the same time and switch back and forth.
-CS! -Brandon
Jerry Gerber avatar
Brandon Tackett:
@Jerry Gerber
-CS! -Brandon
Thanks Brandon!
Jerry Gerber avatar
David Nozadze:
Hi Jerry,
D
Great, that makes it easier!  Thank you David.
Jerry Gerber avatar
Thank you Cornelis!
