Light suppression filter suggestion for Canon Ra ?
2 replies88 views
Thomas LELU avatar
Hello everyone, I am looking for a good light pollution filter but it seems that only the ASTRONOMIK brand sells compatible filters.I would have liked a filter like OPTOLONG L-PRO or IDAS-LPS-D1 / 2.Have you seen these filters for Canon Ra ?
Thank you in advance.
Thomas.
Joel85 avatar
Hello Amenophis,
I'am using an IDAS LPS D2 (D2=D1+ led filter) on my canon EOS 100D . The filter is inside the canon . It's a specific filter for all APS-C models  I think  https://www.teleskop-express.de/shop/advanced_search_result.php?keywords=idas+lps+d2&suchdas=OK
Another way : a filter directly screwed on coma reducer (a little bit chipper and if one of these day you buy a new camera, you can keep it : not linked to a camera model ) . Just calculate backfocus (depending on where the filter is placed)
The IDA-LPS-D2 for APS-C  does not really  change  the backfocus ,  it is near the captor and is thinner than other filters. There is about 2 years that mine is inside the canon ... I can not do without it
Clear Sky !
Supportive
Robert Huerbsch avatar
Are you using a camera lens? If so, a Hoya red intensifier filter will work and I have not had reflection issues with it.
if not, Optolong L-Pro or check www.cyclopsoptics.com for compatible clip filters
Asiair Pro and Canon DSLR in practice
Hi all, I have an Asiair Pro that I use with a ZWO ASI183MM Pro and two « mini » ASI cameras for guiding (plus EAF and EFW). I also have a Canon EOS Ra that I plan to use with the latest version on the Asiair Pro software running on iPad (I read rece...
Discusses Canon EOS Ra camera setup and accessories compatibility.
Apr 26, 2021
