Mike Harris avatar
I have a new ASI294MM Pro (monochrome). I took 100 bias frames at gain 120, offset 20, -10C, and 1x1 binning. The statistics are consistent across the raw frames I examined. However, I extracted the gradient across several of the unstacked frames using ABE in PI with default params and got results similar to the example below. Each frame has a slightly different pattern, but all consistently show low brightness on the left/right edges and higher brightness in the middle. I took additional bias frames with the same settings except I changed the offset to 30. This resulted in the same general pattern, however the gradient is more gradual and extends closer to the edges.
I know I can subtract this gradient in my subs, so am not concerned about imaging impacts (although I haven't taken light subs yet). However, I'm curious if this is "normal" behavior or whether there is a sensor / electronics issue.
Appreciate any thoughts on this.
Arun H avatar
Especially with the 294MM, a bias frame should be used as is. You can read more about the peculiarities of that sensor here. The long and short of it is that, for very short exposures, the circuitry on the chip causes it to heat up to an extent and on a timescale that the TEC cannot handle, leading to anomalous results. Calibration should be done with darks from which bias has not been subtracted and such calibration frames should exceed 3s in duration.
Mike Harris avatar
Thanks, Arun. I knew that there are peculiar bias frame issues with the 294MC sensor, but had not read definitively that the 294MM had similar issues. I'll follow your suggestion about darks exceeding 3s and will continue researching and run some comparisons.
Appreciate your response!
Mike
Mike Harris:
For the record I never encountered any such issue on my 294MC, see master bias below:
Jonny Bravo avatar
Mike Harris:
A bias frame is _NOT_ a 0.1" or 0.2" exposure. That's a dark flat. It's a short one, but it's a dark flat nonetheless.
Fair enough, here is one:
Help ASI 1600mm PRO- Darks' mean ADU unstable
Hello, I've recently had some issues with my ASI 1600mmPRO that I noticed while taking 10 minute darks at gain 200. The camera is not 1 year old yet. Before I explain what I did, all the test were done in exactly the same conditions, same laptop ...
Bias frame stability issues similar to your dark frame ADU drift.
Apr 18, 2021
Yellow banding on LRGB image - help!!
Hi everyone - I very recently transitioned from a DSLR into LRGB imaging using ASI1600MM and as such just starting to learn the processing techniques required for LRGB data. I've come across some odd banding and hoping someone can point me at the...
Bias frame gradients directly cause color banding in monochrome camera stacks.
Apr 20, 2021
Flat Calibration Problem
Hi everyone, I'm having an issue with flats/calibration in my setup. My setup consists of a Carbon TS Newton 200/800 with Starizona Nexus (effectively 200/600), QHY ImageTrain (QHY 268M with QHY CFW), and AstroWanderer Rotator. A screenshot from ...
Flat calibration issues may relate to gradient patterns in calibration frames.
Mar 11, 2025
Diagonal banding in the dark frames
Hello, I've just bought a ZWO ASI585MC Pro, my first cooled astrocam. Didn't get the chance to test it outside yet due to cloudy weather (of course) but I made some dark and bias frames, checked the cooling works, etc., and I've noticed t...
Diagonal banding in dark frames similar to reported gradient extraction patterns.
Nov 11, 2024
Unhappy processing results: Witch Head, APP, many short subs
I just finished 14 hours of CPU time processing 155 15-second subs of Witch Head Nebula. Tracked but unguided, my drive is about 3% slow in R.A. (see separate post under Equipment), forcing me to such short subs. There was a vicious haze where we wer...
Relevant to understanding bias frame calibration for monochrome camera processing.
Nov 9, 2021
