What Is the Ideal Counterweight?
8 replies518 views
Jerry Gerber avatar
I am going to be using the Askar 130PHQ refractor on the ZWO AM5 mount.
I know that there's a trade-off between mount stability and guiding.
I want to understand what the best counterweight would be for this setup.  The scope and accessories weigh around 32 lbs.
I bought a 10 lb. counterweight (plus about 1 lb. for the shaft) but am wondering if a 5 lb. counterweight would be better.
How do I test this and how do I determine the best place on the shaft to put the counterweight?
Rather than give me a complex mathematical formula or equation, I prefer real-world experience if anyone has solved this problem so that guiding is under .7 on both axis and the tripod/mount is balanced.  I am also putting weights in the center pouch of the tripod as well.
Thanks for any insight, deeply appreciated!
Jerry
Geoff avatar
Quick answer: a heavy weight close in is better than a light weight further out.
Jerry Gerber avatar
Geoff:
Thanks Geoff, that's useful to know..
Nick Grundy avatar
Geoff:
Geoff, I assume this is because of possible flex in the counterweight shaft? vs the total payload on the mount/tripod
Just curious why that is
Jerry Gerber avatar
Nick Grundy:
Geoff:
Good question Nick,,  I'd like to know that too.
John Hayes avatar
Go to 49:36 of this presentation:  https://www.advancedimagingconference.com/articles/secrets-long-focal-length-imaging-john-hayes
There is a discussion of mechanical stability including where to put your CWs and why.
Nick Grundy avatar
John Hayes:
so apparently i'm shopping more counterweights
thanks John, that was a great help. (ended up watching the whole thing)
Jerry Gerber avatar
John Hayes:
Thank you so much John for posting the link.  I bookmarked it and will be watching it repeatedly.
I've decided, due mainly to time constrains and seeing conditions to limit my astrophotography to 1000mm focal length using two refractors, a Skywatcher 100ED and an Askar 130mmPHQ.
Being an amateur who just wants to take the best images I can with focal lengths from 358mm to 1000mm,  I think it will make imaging a bit easier and more enjoyable.
 Your sense of humor really made me chuckle and the image of 3 telescopes on top of each other on one mount  was hilarious...
Jerry
Respectful Supportive
John Hayes avatar
I'm glad that you guys found that presentation useful.  It's a talk about "long focal length" imaging but in reality, most of it applies to pretty much all kinds of imaging!
Cem40: RA jumps around in 5-7 mins
I started having this issue where it seems the mount jumps a bit every 5-7 minutes. It happens quite consistently. I can see that in my auto guider view, the stars move at the same time I see a jump in RA error. I use ASIAIR for my captures, guiding ...
Discusses counterweight balance trade-offs relevant to your new scope weight problem.
Sep 2, 2021
More couterweights or closer conterweight ?
I recently stumbled onto this question while setting up my rig a few days ago. Would you put more counter weights but closer to the mount or less but farther on the shaft ? The resulting balance would be the same but you would have more weight on the...
Discusses counterweight trade-offs between mount stability and guiding performance.
Jun 4, 2021
EQ6-R or GEM45
Hi guys! Which one to choose between these two mounts, EQ6-R or GEM45 ? Both have a working capacity of 20 kg (44 lbs), but the EQ6-R weighs 17.3 kg without tripod and counterweights while the GEM45 weighs only 7.2 kg without tripod and counterweight...
Discusses counterweights relevant to equatorial mount selection and setup.
Nov 9, 2021
HOW TO : Balancing a RC scope on the mount ?
Hi All, I have a RC8 - pseudocollimated thanks to the help of the community - and I think I should really improve my guiding. Among the things to improve that I have spotted is the balancing of my system : with the RC8 and the camera/filterwheel/OAG/...
Counterweight balancing directly addresses author's back-heavy RC8 weight distribution problem.
Apr 23, 2021
Lacerta f4 250/1000 carbon fibre scope on a Skywatcher AZ-EQ6 pro mount, users experience please
I have the Skywatcher f5 8" Newtonian with an AZ-EQ6 pro mount on a Skywatcher pillar, which I am very pleased with and I am thinking of buying the Lacerta 250/1000 f4 carbon fibre scope instead to reduce imaging time. I see that a number of peo...
Counterweight balance relevant to mount stability with heavier scope.
Jul 12, 2021
