Removing dust from optical surfaces
3 replies221 views
Anderl avatar
Has anyone tried to remove dust from optical surfaces like mirrors, filters and glas by blowing ionised air out of a hairdryer on it?
Reason i ask is, i have a l-ultimate that is impossible to clean, no blower, no cleaning solution, nothing seems to be able to remove the dust particles on the surface of this filter.
cs
Andi
And why should you? You risk ruining it for no advantage at all. And, yes I did and it didn't work.
Anderl avatar
Just had the chance to test it.
worked great and solved my problem. I think lot of dust creating dustspots is a problem and ionised air is an easy fix for that.
Brian Puhl avatar
I just use one of those mini duster guns from Amazon that I picked up the other day, working very well to keep the dust off as I'm assembling.   I don't have anything caked on tho.
Antlia LRGB filters & GSO RC off-axis ghosting problem.
As is generally known, the GSO RC telescope series suffers from having too short a 1ary baffle. This admit light rays from outside the field-of-view, causing large and wide faint arcs in field, with a radius of curvature comfortable larger than the s...
May 25, 2025
Both posts discuss practical solutions for fixing common optical problems that interfere with telescope performance.
