Thermal shock & inner condensation, cooled cameras
12 replies606 views
Gabriel Perano avatar
Hey guys!
Just got my first dedicated camera (ZWO 533) coming from a DSLR.
Real quick question with avoiding thermal shock & inner condensation, when cooling & warming the camera what is the minimum cooling & warming time I should apply? I normally average around 10 degrees celsius as an ambient temperature at night & I was thinking of cooling down maybe to -10 to -15 (Not sure how achievable this actually is as I'm yet to shoot with it). I was personally thinking a minimum of maybe 8 minutes for cooling & warming?
Thank you,
Gabriel
The camera software will apply an appropriate ramp in cooling down. Don't worry about the warming up (I normally switch the thing off once I'm finished with the session). My advice is to cool down to -10 and see how it goes before going any further down. If all is well take the temperature down and if no frosting appears than you'll be alright.
Concise
Tim Ray avatar
Hi Gabriel,
I have the 533mcPro and operate the camera at -10C during all but the hottest summer months in North America (0C). I have SGP set to cool the camera on connect over a 30min time period. That is when I do a Polemaster polar alignment and an autoguider calibration. I have a masterDark library of darkframes created at those temps at 0gain, 100gain and 200gain at 30sec intervals from 30sec to 600sec subs. The amp glow on the 533 is extremely low. I doubt any additional benefit would be achieved going below -10C. I do a warmup over a 10min period while I transfer the evenings data from the mini-PC at the mount to my main computer inside. IDK if that is necessary but since I still have the mini-PC on why not…
You will love your 533!!!
CS - Tim
Andre Vilhena avatar
Hello Gabriel,
I usually have a 5 min ramp to cool and to warm the camera. But let me challenge you in one thing: maybe you don't need to cool to negative temperatures, as thermal noise of that camera is quite low. As far as I can see in the website, the thermal noise is as follows:
T (ºC)     DarkCurrent (e/s)    ThermalNoise (e (300sec))
0                    0.00195                               0.765
-10                0.00050                                0.387
-15                0.00025                                0.274
In the last column, you have the thermal noise of a 300 sec exposure.
Depending on the sky you shoot, your shot noise for the same 300 sec exposures (considering a color camera and an F5 telescope) should be:
Bortle                 SkyBack (e/s)                 SkyBack (e (300sec))                 ShotNoise (e )
2                                0.30                                              90                                    9.49
4                                0.57                                             171                                 13.08
6                                3.97                                           1191                                 34.51
8                                8.30                                           2490                                 49.90
Since you add noises using the quadrature rule, and considering the worst case (0ºC), the combined noise is as follows:
Bortle                 ShotNoise (e )               Total Noise (e )
2                                    9.49                             9.52
4                                  13.08                           13.10
6                                  34.51                           34.52
8                                  49.90                           49.90
So, you should be fine shooting at 0º or even a bit higher as it barely contributes to the noise and has several advantages such as less stress on the sensor and lower power consumption.
Just a thought… smile
Note: I have assumed an OSC camera with clear filter. Final conclusion may vary according to filters used or mono/OSC.
André
Arun H avatar
Andre Vilhena:
T (ºC)    ThermalNoise (e/s)    ThermalNoise (e (300sec))
0                    0.00195                               0.585
-10                0.00050                                0.150
-15                0.00025                                0.075
Hi Andre -
To be accurate - your numbers are not thermal noise but actual dark current. The noise from this dark current will be the square root of these numbers (from the Poisson distribution).
Well Written Helpful Insightful Respectful Concise
Arun H:
Hi Andre -
Hi Arun,
That is correct and thanks for bringing it up - post is now revised. Despite forgetting to take the square root for thermal noise, final conclusion still holds.
Cheers.
Arun H avatar
Andre-
yes, this is the way to look at it. I made a similar point in a different thread. Once your shot noise from sky becomes dominant, there is no benefit from cooling further. Do note that the sky background will be significantly less than your numbers if you are doing narrow band and there, there is probably some benefit to going deeper in terms of cooling.
Arun H:
Andre-
Yes, correct. In this case I assumed it was an OSC with a clear filter, since it is the first astrocamera of Gabriel. Of course there are several assumptions here, like the f-ratio of telescope and the use of a clear filter (if any), and conclusion may vary according to those conditions.
Wow guys thank you for the information!
This above & beyond! I always forget how helpful the Astro community can be.
Thank you
Gabriel
Respectful Supportive
Andre Vilhena:
Hello Gabriel,
0                    0.00195                               0.765
-10                0.00050                                0.387
-15                0.00025                                0.274
2                                0.30                                              90                                    9.49
4                                0.57                                             171                                 13.08
6                                3.97                                           1191                                 34.51
8                                8.30                                           2490                                 49.90
2                                    9.49                             9.52
4                                  13.08                           13.10
6                                  34.51                           34.52
8                                  49.90                           49.90
Just a thought...
André
*Hello Andre, thank you so much for the information above. That is certainly a good point & something I will be implementing into my imaging. Everyone here is above & beyond, thank you for the help
Gabriel
JohnAdastra avatar
Gabriel,
Cooling too fast in humid summer weather can lead to condensation on your sensor chip. With my ASI071MC-P I would see a honeycomb pattern (from the circuitry or densities in the glass?) in my subframes for the first 30 minutes of shooting at 0C. I solved this by not cooling faster than 15 minutes in the summer, or 5 minutes in the winter. Also to avoid condensation, you should try to keep your camera in dry conditions when not in use so as not to deplete the desiccant pellets. I keep a plastic baggie over the cam as it sits on the scope in my roll-off between sessions or through rainy weather. The pellets can be re-dried as needed in a microwave according the the ZWO manual. If you ever see unexplained patterns on your subs, condensation may be the cause.
Helpful Concise Supportive
Dale Penkala avatar
I would agree fully with @JohnAdastra as I have the 071 as well as the 294. I have found that the 294 is more subject to this than the 071 however. I used to go to -15 but because of the summer months here in Michigan I found that I can’t get to it easily so I have shot at -5 year round without an issue and I’ve been happy with the results.
I also agree with @andrea tasselli in that most software seem to have the ramp up/down controlled in the software. At least it seems like it in SharpCap Pro.
Congrats on the new 533 btw! You’ll enjoy it for sure!
Dale
atlejq avatar
Some background material for calculating subexposure and camera temperature:
The first link has a very relevant section at 20:40
https://www.youtube.com/watch?v=3RH93UvP358
https://www.youtube.com/watch?v=ub1HjvlCJ5Y
http://www.tools.sharpcap.co.uk/
As others point out here, hard cooling may be rather irrelevant for LRGB, but very relevant for narrowband. Note also that dark current grows in a strongly nonlinear way with temperature, so getting to 0 C from +10 C has more impact than going to -10 C from 0 C.
You can find the sensor dark current here as a function of temperature, it is a straight line in a lin-log plot, hence exponential.
https://astronomy-imaging-camera.com/product/asi533mm-pro
Equipment cold weather equalization
Hi Folks, With fall and winter approaching.. I was wondering what the best way was, to equalized equipment temperatures when I take it outside, and bring it in after a nights session…. I'm mostly concerend with mosture / condensation formin...
Directly addresses temperature equalization and thermal shock prevention for equipment.
Sep 13, 2024
Cooling ideas?””
Hello all! I live in Michigan and sometimes we get really warm summer night! I was out last night and while its not technically summer it was quite warm! 77º for the most part and 72º by 5am. I’m sure many of you live in warmer climates as well and a...
Discusses thermal management issues relevant to cooled camera operation in warm conditions.
Jun 5, 2021
