I made my own power station and decided to oversize the box. I recommend taking inventory of your current receptacle needs and try to think about what you want in the near future. Also if you are willing to make your own power cables (photo below), you can standardize your needs. I have replaced almost all my plugs with anderson power poles.
The receptacles are pretty easy to swap out, so don't feel bad if you need to change in the future. Powerwerx sells a lot of different varieties.
https://powerwerx.com/panel-mountsHere is mine if you want some inspiration.
Additionally I installed a radio for some entertainment in the middle of nowhere. It can pick up AM/FM or play bluetooth/3.5mm input.
Finally I installed white or red lights for when I need them. I left them on velcro so I can point them around.
Internally, I am using a blue seas fuse block:
https://www.bluesea.com/products/5026/ST_Blade_Fuse_Block_-_12_Circuits_with_Negative_Bus_and_CoverYou don't need to get this fancy, but I strongly recommend you find a way to make sure each port is fused to protect your gear.
I like that this uses standard blade fuses, so you can pick them up at any auto repair shop or by the dozen online.
Make sure the battery is protected as well with an appropriately sized fuse as close to the terminal as you can get. I went with one of these:
https://www.amazon.com/gp/product/B0019ZBTV4For monitoring, I am using a victron smart shunt:
https://www.victronenergy.com/battery-monitors/smart-battery-shuntThis is mega overkill, but it is nice to be able to see the status of the battery from my phone as well as some history. Some of the panel mounts in my first link also act as battery monitors.
