Siril RGB Align Script to remove certain chromatic aberrations.
Siril Enthusiasts 3 replies178 views
Brock Johnston avatar
I love my Edge HD 9.25 and its 0.7 reducer; however, it has some chromatic aberration around the edge of the frame, primarily shifting the colours radially. I have been manually splitting the image into R, G & B images, re-registering and re-compositing them. This takes a few minutes, so I created a script that runs these steps automatically. Now it takes just two clicks and a few seconds.
This is an image from the lower right corner of a frame, the top panel is raw and the lower has the script applied.
I have attached the script. Feel free to use it, and improve it.
Brock Johnston
RGB Align.ssf
Dean Ostergaard avatar
Wait! You're saying I can take my OSC subs, split the channels and process them like monochrome?!
Why doesn't anyone talk about that?
Maybe they do. I only got into AP this year but this is something I totally missed. I will be studying your script, for sure.
EDIT: I misunderstood what your script does. I thought you were splitting each sub then processing them as if they were different filters from a monochrome session. I wonder if there would be any value in doing it that way. Perhaps split the RGB then use the original for luminance?
This is still a cool idea though and I will try it to see if it can reduce or eliminate the chromatic aberrations I get with my inexpensive Achromat doublet. Thanks again!
Taman avatar
Brock Johnston:
Brock Johnston
Thanks for this Brock, it works perfectly! I have the same problem when I use an OSC with my Starizona reducer, the RGB channels are not quite aligned.
The only thing I would do to improve it is to have  the temporary "RGBA" directory created from within the script, otherwise you have to remember to do it first. I can't see an easy way to to this, as Siril does not support a make directory mkdir or equivalent command. For an all in one solution, It could also be added to the OSC_Preprocessing script.
CS, Tony.
Well Written Helpful Insightful Respectful Supportive
Brock Johnston:
Brock Johnston
CS, Tony.
Taman, I also was hoping I could have the script make a new directory, or delete them files from a previous use of the script, but the commands available did not seem to facilitate it. Thanks for the feedback.
Cheers, Brock
Canon EF 300mm f/4 L astrophotography comparison: non-IS vs IS version
Hello all, I am excited to share this test report I wanted to make ever since I acquired both lenses, in an effort to help the community. I will also attach it to the thread for easy download. Enjoy your read and I hope this comparison helps you make...
Feb 3, 2026
Both posts describe efforts to address optical imperfections in imaging equipment by creating or sharing solutions to help the astronomy community.
