RCC - Rosette Nebula
4 replies188 views
Benjamin DeHaven avatar
Hello! This basically boils down to I am not entirely happy with the color, or lack there of in the center of the nebula. I think this is due to using an unmodified DSLR (Nikon D850). I edited it twice in Pixinsight with similar results so I don't think there is more red hiding away. Thoughts in general? Thanks!
Rosette Nebula
Benjamin
Oscar H. avatar
Do you mind if I download the file and edit it and try to improve it?
Well written Respectful
dkamen avatar
Seems a little overexposed to me. It is red, only shifted towards white.
Oscar H. avatar
I think the pinkish hue is because of too much blue, I don't know why the center is B&W.
Doug Summers avatar
You might try using a range mask on the inner region, and then bring the brightness down.   What reds are available will then begin to pop a bit better.   Once you do the inner region work, you could experiment with inverting the mask and attempt to raise some of the fainter outer region.   I think there's still a bit of nebula out there to raise.    Good luck and CS,   Doug S.
Well written Helpful Respectful Concise Supportive
[RCC] Soul Nebula: Where is my OIII?
Hello everyone. I recently purchased my first dedicated astronomical camera (Playerone Ares-C) and am finally starting to get some data that can be considered as such. After a few short acquisition tests, I finally managed to acquire a substantial da...
Soul Nebula author also struggles with missing narrowband data in unmodified DSLR.
Nov 3, 2024
[RCC] IC5146 combining OSC broadband and dual narrowband
After being into astrophtography for almost 3 years now and using pixinsight for a year, I am definitely enjoying the improvements ive seen since even earlier this year when I felt confident in getting my images rated. Anyways my latest image is one ...
IC5146 author combines broadband OSC with narrowband; addresses color/data limitations.
Sep 12, 2024
[RCC] Horsehead Nebula
Request your feedback and critique on on the image below. This is a quick one night integration (5 hours only), will be taking another pass by adding more data and including improved post-processing based on critiques! What I can see very evident is ...
Horsehead Nebula post seeks feedback on nebula imaging similar to Rosette.
Dec 1, 2024
