William Optics FLT Dew Shield
10 replies277 views
Maged avatar
Hello, I want to ask if there is a way to remove the dew shield of the William Optics FLT91 scope? I know it can be retracted but l'm trying to remove it to be able to put it in a travel bag. Can you please share with me if that's possible and how can I do it?Many thanks,
Francois Charron avatar
Yes take the locking screw out, and then just unlock the rear ring portion from main hood.
Maged avatar
Francois Charron:
Just to confirm, is this the rear ring portion you are referring to? It should be unscrewed right?
Francois Charron:
Correct that’s the ring part. To get the ring off the scope as well I’m not 100% sure, you might have to remove the lens cell first. The hood portion should just Slide Over the cell
William avatar
This is great. I didn't know it came off. Although I do have the original case mine came with and it fits in there with the dew shield.
Taman avatar
I wouldn't recommend removing the lens cell as suggested! The easiest way is simply remove the scope from the dovetail  and close the dewshield down. It will then hopefully fit in your travel bag. Also if you remove the dewshield, the protective lens cap won't fit.
Cs, Tony.
Maged avatar
Cs, Tony.
That’s definitely better for the protection of the lens. But are you sure the dew shield can slide down the train after removing the dovetail so decreasing the overall length of the tube?
Taman avatar
I've just checked mine. Remove the scope by undoing the 2 clamps,  the dew shield then slides down to within 18mm of the front of the scope. You will have to pack the dovetail separately though.
Tony.
Maged avatar
Tony.
I would be very thankful if you can share a picture of it.
many thanks for your help
Taman avatar
Tony.
Pictures as requested. The scope including reducer is 57cm long with the dew shield extended. Folded up it's 50cm and fits in the carry case. Hope this helps, Cs, Tony.
Maged avatar
Tony.
Thank you so much.
Fluorostar 91 -ZWO EAF
Has anyone ever put a ZWO EAF on a William Optics Fluorostar 91? just curiosity to see if it’s compatible Ricky
Addresses William Optics FLT91 physical modifications and accessory compatibility questions.
Oct 7, 2021
Please give me accessories and equipment suggestions for the Flurostar 91 APO William optics
Hello, I would like to have some suggestions for equipment because i'm having trouble finding accessories that are good. Also please give me some places to go look at the night sky with
Discusses William Optics equipment accessories and troubleshooting.
Feb 20, 2025
What Purposes The Dew Shield & Bahtinov Mask Have?
Okay, I know it's kind of an obvious question. But for some context, I wanna know what the purposes of these 2 accessories have. As I know, the Bahtinow mask helps Seastar see the stars better. But what purpose does The Dew Shield have? In any wa...
Explains dew shield purpose and function for telescopes.
Nov 8, 2024
FLT 120mm: measurement from the bottom of the dovetail to the top of the handle bar?
I am going to be purchasing a William optics FLT 120mm and I wanted to know the measurement from the bottom of the dovetail to the top of the handle bar since I’m going to be buying a case that fits it. If anyone has one and can measure for me that w...
Addresses William Optics FLT telescope specifications and measurements.
Nov 14, 2024
