TS 65 or Redcat 51
11 replies434 views
Alan Hancox avatar
Hello
Sadly one needs to go. I'm torn over which one to get rid of.
Which one would you sell and why?? I need help and advice…
Thanks for reading…
Alan
Sascha Wyss avatar
I never understood the Redcat 51 - it is way too wide. So I would kick the cat out and keep the TS which has an ideal focal length for most objects. Also the redcat will be easier to sell as out of whatever reason (probably the looks) there is still a high demand for it.
AdamJ avatar
Well the FOV depends on the sensor as well as the focal length. I image with a 180mm FMA180 and its not too wide for the objects I want to image when I pair it with my ASI1600mm pro. The detail you resolve is also based on SNR as much as focal length the TS is only F6.5 and that is significantly slower than the Redcat.
What camera are you using with the scope?
Adam
Alan Hancox avatar
Qhy 168c (same as zwo 071mc pro)
Joe Linington avatar
I wonder if the Tak TS 65 would stand up to the Starizona .65 reducer. I would keep the TS 65 if there was a .7 or better reducer available. That would give you 2 scopes for you money and it uses a regular focuser without using belts or things.
If there isn't a reducer, I'd likely keep the faster redcat, or sell them both and buy an Askar 400/500 with the .7 reducer.
Jesse Priolo avatar
I've only ever seen a very few SpaceCat/RedCat images that could stand up to close scrutiny. They're stylish pieces of kit, sure, but don't seem particularly good optically. Even most of the IOTDs with them here on Astrobin are either so down-sampled that you can't check out the detail, or rife with edge-of-field aberrations.
While not perfect, I still much prefer the output of my Canon EF 200mm f/2.8 LII (@ F/4) - a 27 year old DSLR lens - over just about everything I've seen out of a RedCat.
I have no experience with the TS 65.
Well Written Insightful Respectful Concise Engaging
Rajat Kumar avatar
There is Askar PHQ65 with .75 reducer. The big difference between TS and PHQ is that latter is a quintuplet. Another option to consider?
Following this discussion closely.
Piers Palmer avatar
Which do you enjoy using more? I think this is often overlooked. For me astrophotography isn't simply about the end result, but the process and I know, out of my three scopes, I enjoy using my 82mm refractor the most. I find the Redcat finicky to use and I don't like the focus mechanism…for example.
Do you find yourself going to for one over the other generally?
Alan Hancox avatar
No not really Piers. I actually think I have a really good specimen of both the 51 and TS. I know the TS is harder to find used as people tend to keep hold of them….
Piers Palmer avatar
Then yes, you’ve got a dilemma!
AdamJ avatar
Alan Hancox:
Honestly, I would stick with the TS if I had an APS-C sized sensor with the pixel size the 071 has. With it being OSC then the sampling is going to be very low on the redcat.
My FMA180 mainly works out in terms of sampling and detail due to being used with a mono sensor with smaller pixels than the 071.
The other option is to sell them both and go for the middle ground at about 300mm F5:
https://www.firstlightoptics.com/askar-telescopes/askar-fra300-60mm-f5-petzval-astrograph.html
Adam
James avatar
Technical aspects aside.. when you imaged with each of them..
-Which one was more enjoyable?
-Which was easier to work with?
This is a hobby.. I'd keep the one that's been the most fun to use.  smile
Thinking of adding the Apertura CarbonStar 150 w/0.95x Comma Corrector to my collection
Hi Folks, As the subject line says, I'm thinking of adding the Apertura CarbonStar 150 to my current collection of telescopes…. My current collection consist of in order of shortest to longest focal length: WO Redcat 51, Celestron C6-Hypers...
Author considering telescope collection changes; adding equipment context relevant.
Aug 27, 2024
Gear advice
Hello, Please feel free to let me know if this topic is in the wrong area… but I have the 9.25" EdgeHD. I have been using it for a few months now, primarily for visual work and just learning the scope and mount. In the time that I have had...
Directly addresses gear advice for telescope owners managing equipment.
Dec 16, 2024
