Best Quality Pics for the money
11 replies652 views
M16 avatar
Hello, please i need your help because i'm a little lost in the space of astronomy equipment :-)
I have read a lot of thread (my eyes are burning ;-) but i think i can't understand more now
So my project is to try to make astrophotography, i'm thinking about deepspace
what instrument will you choose please for deep sky astrophoto ?
I'm thinking about a budget of 3500 - 8500 €    // 3700 - 9100 $ only for the instrument.
I'm searching about the best quality in photo and optical
I'm thinking about Celestron RASA, TAKA Epsilon, TAKA FSQ or TAKA TOA
Shame on me : I'm a noob
I'm thinking about astronomy a lot of time but i've been discouraged each time : it's difficult to understand astronomy equipment.
But a few time ago i take my first deep sky photo : M42 with an hybrid and a tripod
I was really surprised about it, and it make me thinking an other time about astronomy.
I read a lot, i have understand a little :-)
But this time it's certain i want to buy an equipment.
Thank you so much for your help and have a good day.
Joe Linington avatar
SharpStar 61EDPH/Askar 300 or 400 or similar, a mount much bigger than you think (EQ6R Pro and bigger) and then decide if you want to start with OSC for simplicity or just dive into mono imaging and save money over the long run. Play with that then decide on the fancy optic. Unless you are buying a full frame camera like the QHY600 or ASI 6200 you will find many scopes that are very, very good for a lot less and when you have some experience you will know more if you want fast, wide or deep which will dictate what you buy next.
Jay Hovnanian avatar
There's no shame in being a Newbie - we all start somewhere ... and though it would appear you can afford to enter the wonderful world of Astrophotography at the higher end, I'm with @Joe Linington .  Start easy (which still is not inexpensive) and get a smaller Refractor from Askar or William Optics.  The optical quality of so-called mid-grade telescopes is getting better and better.  Your mount choice will strongly influence the quality of your images.  There are hundreds of superb images here on AB taken with smaller scopes and an EQ6R or mid-capacity iOptron mount.  And, that's just the beginning ....
Unless you already own a suitable DSLR, my additional two-cents is to start with an APS-C dedicated Astro color camera, and get a ZWO ASIAIR-Plus.  You will also need a small guide scope, guide scope camera and 12-Volt battery.  Again, still just the beginning ....  There's more even before you have to consider how your images are going to be processed.  Many online tutorials exist.
I say all of the above as having experienced all of what you are considering, BUT, having started with a fairly high level of understanding (albeit many years ago in the world of film).  I knew the sky, telescopes, mounts, photography  ... and thought I could just waltz back into Astrophotography.  Basically, I knew NOTHING and had A WHOLE LOT to learn.  I made a number of ill-advised Newbie wrong choices.  Nevertheless, I am still eager to learn ... more and more.  Astrophotography is an awesome hobby and can be wildly rewarding.
Many have gone through what you are going through.  It'll take some time and experience, but (again) start more simply and grow from there.
We all wish you well, I'm sure.
Dale Penkala avatar
Yes I’m with @Joe Linington & @Jay Hovnanian start slow and keep it as simple as possible. Once you get some experience under your belt grow from there but don’t be in a hurry. Thats when you will make mistakes and mistakes can be costly!
I agree with getting a larger mount that will give you room to grow with and start with a nice refractor and learn the setup and processing and adjust and grow from there.
AP is a wonderful hobby but there will be frustrations that will come with it but we all here on AB are here and we help each other thru the frustrations 😊
Dale
Engaging Supportive
M16 avatar
thanks you for your time.
Astronomy and astrophotography =HwtZe=jCAhz ChMk0b=ryNqvbseems to bring together nice, caring and Passionate people !
I'd love to discover and learn about the equipment.
I have looked at many photos on Astrobin and my preferences seems to be the ones who are taken with focal about 800-1000mm
But if i have understood correctly it's perhaps more difficult to use high focal length ?
What do you think please about pegasus NYX-101 on EQ6/AZEQ6=HwtZe=jCAhz ChMk0b=ryNqvb Tripod ?
I was thinking about taka FSQ because it's seems to be so good on the pics and perhaps "more easy"  for a Noob ?
Lynn K avatar
Takahashis are nice, but a new FSQ106EDX4 will take almost all of your highest budget.  I use a  older version FSQ106ED and it is a greate scope, but I bought used AND didn't start out there.
The FSQ is also heavy for a 4" scope and will demand a better mount. To put that scope on a cheaper mount is a waste of money.
I would agree with the above and start with a 60 to 80mm asian refractor.  Also, put most of you budget into the mount.
Lynn K.
Helpful Concise Supportive
Jesse Priolo avatar
Perhaps there are some exceptions, but a big reason images taken with the FSQs look so good is because they are often made by astrophotographers who are very experienced in image acquisition and processing, who eventually upgraded to a premium astrograph after learning the basics on more modest equipment.
A quality 80mm F/6 scope, an EQ6-R, an ASI2600MC/MM, and a good book on learning PixInsight will get you started on the right foot - and you'll still be able to use it even after you start upgrading your gear, once you have a few years of practice under your belt
Tim McCollum avatar
In 1997 I bought a 10" Meade LX-200 which I thought was a very beautiful piece of equipment.
I was in my early 40's then and could man handle it to the yard and get it setup on the mount but it was still a job,
As time went by I used it less and less.
For 15 years it mainly just sat in the corner of our bedroom covered with a dust bag, and I got to thinking for about the same amount of money as I had in the scope I could build a small OBS and get much more use of it.
Well I decided on a 10'x10' ROR which I built and installed the scope only for visual use (I knew zero about AP).
Next I got a super wedge for the LX-200 mount and a T adapter for a Canon camera, took my first picture of M42 and like a super drug, I was hooked.
Any free time I had I was always thinking about AP, I had no idea how to stretch an image to see what I had captured, thank goodness people now have YT to learn some simple processing from.
I next got an Avalon M-Uno mount which worked very well and currently have my last mount which is a 10 Micron GM2000.
The SCT (LX-200) was the very worst scope to start AP with, I got a Meade 6000 70mm refractor which has a focal length of 350mm and that would be a good scope to start learning with.
If you really think you will stick with the hobby then buy the very best mount you can afford and upgrade scopes as you learn.
It will take you years to get good at it, you will likely go weeks at a time unable to use your equipment due to weather, the Moon and other reasons, be very patient.
We all see the beautiful scopes, cameras and pictures in the ads, but a seasoned imager knows that a good mount it the real secret.
When you have to fight the mount you wind up with nothing for a long nights work.
Sorry for the rant, I wish we lived near each other so I could offer help first hand.
Refractors just work out of the box, you don't have to mess with aligning optics that you know very little about, I lost a whole summer fighting a beautiful RC8 that I could not get round stars with, bought a Williams Optics scope and have never had to touch it as far as alignment goes.
If you keep going it the hobby you will see new people complaining about the weather all the time, you have to just accept that there will only a few days each month that are good enough to be able to use your gear (unless you live in a really good location).
Starting out, keep it simple. Good mount, short FL refractor, DSLR or OSC astro camera and small enough to setup and take down depending on your location.
I would suggest studying the ZWO AM-5 mount and ASIAir Plus equipment. I have the ASIAir Plus as part of my portable rig.
Good luck,
Tim
Tim McCollum avatar
The only shame is if you don't ask.
There are no stupid questions here.
Tim
Ralph Ford avatar
I have been helping a friend get started this past year.  There is some equipment that will always be kept because it is so versatile.  I would start there and not be overwhelmed with complexity.  My friend had a Nikon DSLR and some good lenses.  I suggested he start with a camera tracking mount.  He had immediate success with little frustration.  On the plus side he has equipment that will be useful for years to come.
A year in, he has a WO Redcat, and an AT 115 for imaging.  He also purchased a GM811, and ASI APS-C OSC color camera.  He is using NINA, Sharpcap, and Pixinsight.  It hasn't been a perfectly smooth journey, I think he has added too much complexity too fast.  That said, he is getting some excellent images.
M16 avatar
Hello finally i make the big jump !
At first i had planned my hybrid on an AM5……
But i've found a Taka Toa 130 NFB in stock !!!
And finally i decided to put it on an EQ8 -RH an his tripod
The Budget will be repaid over generations……
I'm thinking about create an other post perhaps to have an help about the configuration ?
I mean about the rest of th equipment ?
14" Goto Dobsonian vs C11 on AM5 for beginning planetary
Hi everyone! I'm trying to decide what setup should I invest in to take beautiful images of the Jupiter, Saturn and Mars, as well as Moon craters and optionally sun spots. For now I've settled on two possible candidates: - Sky-watcher FlexTub...
Discusses telescope selection for imaging; relevant to equipment choice decision.
Aug 19, 2024
EdgeHD 9.25 w/ 0.7x Reducer and 2" Esatto Questions
I am entertaining the idea of getting a Celestron EdgeHD 9.25 with 0.7x Reducer along with a PrimaLuce Esatto 2". I understand that the Esatto goes after the reducer and you add spacers to reach the 146mm needed (77mm after the Esatto itself). I...
Details specific telescope setup for astrophotography; directly relevant to instrument selection.
Sep 14, 2024
