FSQ-85 .73x +full frame
2 replies342 views
Dan Brown avatar
Howdy all. Could someone shed some light on the image quality of this combination, Takahashi FSQ-85 with .73 reducer and a full frame camera? This would be a good angle of view for large subject matter like Rho Ophiuchus.
Thanks,
Dan
Bruce Donzanti avatar
Hi Dan
I use a full frame camera (ASI6200mm) on my Baby Q but I only use the 1.01X flattener with it.  I have had no issues with this combination and have posted a few images with this setup on AB.
Bruce
Larry S avatar
Dan,
I tried the Tak .73x QE reducer with my Baby Q and did not achieve satisfactory results with anything bigger than a 1" sensor (ex. ASI183). For 4/3, APS-C, and full frame it was horrendous. Terrible star elongation, and I could never resolve it by back-focus adjustment (shims ad infinitum). Even with 1" sensor, tilt was a problem (QE reducer grub screws?) I could not resolve. Finally sold the reducer and now only use the 1.01x flattener for good results out to full frame DSLR.
I thought about trying the TKA82580 CR 0.73X Reducer (no grub screws, so maybe less tilt problems), but they are hard to find and expensive. For now, when I want wide angle images, I am using the Samyang 135 f/2.
I would recommend mosaics with 1.01x rather than using the 0.73x QE reducer.
filter size and impact on vignetting
Hi all, I've been using my 160ed for some time now with an EFW and 50mm filters. (directly attached, asi2600+EFW) That puts the filters about 20mm away from the sensor. (i think) in calculating the angle of incidence at the edges, at F3.3, even a...
Discusses filter vignetting effects relevant to FSQ-85 full frame imaging setup.
Sep 7, 2024
Takahashi's bad focusers
I am an owner of two Takahashi telescope models, one is an E-130D and the other a FSQ-85EDX, with the newtonian being my main setup at the moment. I think it's an unanimity that Takahashi is known for being one high end brand when talking about o...
Addresses FSQ-85EDX focuser issues directly relevant to poster's equipment.
Oct 7, 2024
