Flats problem
Renaat VandewieleRoger Nicholandrea tasselli
25 replies667 views
Renaat Vandewiele avatar
I have an issue with my flat frames.
for example : to me everything looks normal in the preview ...
now if I go stacking I get ...
without flats I get
I stack in PI
does anyone have an Idea what could be wrong here? Using an Altair hypercam 294c PROTEC. I have managed to get a decent looking image with using only the blue channel from the master flat but that does not seem an option for me  to do this every time
note : i DID clean my rig in the mean time
Joon Ren avatar
Were you using local normalisation by any chance? If the reference image has flaws, it will cause an uneven discoloured background. Another possibility is if the flats or lights were not calibrated properly, the flat corrections will be inaccurate.
Well Written Helpful Concise
Michael E. avatar
How do you acquire your flats? Are you perhaps using a DIY flat-panel with the led-lighting not being uniformly enough?
Because your first image looks pretty uneven to me, displaying a similar pattern as in your stacked and corrected image.
If you're not already doing so, it might help to produce the flats by pointing the telescope to the sky at dusk, with or without a t-shirt.
Well Written Helpful Insightful Respectful Concise Engaging Supportive Perfect post
Michael:
Hi Michael, I'm using an ipad with a double layer of white tshirt. I'm using the ekos flat wizard that will automatically look foor 3200 ADU and determine the exposure time
is that a setting in weightedbatchprocessing in PI?
thank you for the reply
Michael E. avatar
Hi Renaat
I still think the uneven screen illumination of your  iPad might be the cause. Try the "sky-method" occasionally, at least you can rule this out as an error if it won't help.
clear & even skies :-)
Michael:
Hi Renaat
Will do thx
ok so here I am pointing at the sky with 4 layers
Jonny Bravo avatar
Renaat Vandewiele:
without flats I get
I stack in PI
294... you're going to need a different light source. When I first got my 294 (mono) I was using an iPad as my light source. My red filter looked exactly like what you're presenting here. I stopped using the iPad... no more problem with the red calibration.
Apart from the issue with using an IPad as flat panel (bad idea unless you put a lot of diffuser screens in between) your master flat looks wrong. it shouldn't be de-bayered at all. Just remove the master dark-flat from each of the frames and stack in PI using multiplicative normalization, no weights and equalize flux.
Concise
Joon Ren avatar
Renaat Vandewiele:
@Renaatit is turned on by default in certain versions of Pixinsight. More info here https://www.cloudynights.com/topic/826992-turn-off-local-normalization-in-pixinsight-weightedbatchpreprocessing/
Also, +1 to what Andrea said above. Don’t debayer the flats when calibrating. If you’re using WBPP it should do exactly that but won’t hurt to check.
Tom Boyd avatar
Maybe way off base here, but curious. Are you concerned by the red circular streaks in the stacked image? If so, these look to me like ABE artifacts. Could you repost simply using an unlinked screen stretch? Simply take your raw image, and before you screen stretch it, de-select the little chain link icon on the upper left of the ScreenTransferFunction. This will stretch each of your color channels independently. If the unlinked screen stretch images looks ok, get rid of the background gradient using DBE instead ABE.
Just a thought…
Jonny Bravo avatar
Tom Boyd:
Just a thought...
It's not a background extraction artifact. It is an issue with the 294 sensor and using an iPad as the light source for flats.
restacking with sky as lightsource now … we'll see..
I have tried dbe and abe for extraction method. stacking almost done .. :-) we'll see
ok it looks different (not talking about the object I had the same problem with this one. So i redid the flats with the sky as a lightsource with shirt 2 layers. I did not change the parameters of the preprocessing yet.
and after a quick hist transfo
Thank you all for the responses!!
Roger Nichol avatar
Can you confirm what your flats exposure duration is? You need at least 3s for that camera.
Roger Nichol:
Absolutely NOT.
0.19s is automatically set
Roger Nichol avatar
The ASI294MC, which uses the same IMX294 sensor has a recommendation of 5s due to a characteristic of the sensor - from what I've read it switches to settings optimised for video below 3s which introduces some non-linearity (?)  (I can't find a reference for that apart from numerous reports on cloudy nights, FB, etc.)
"2.  I’ve heard there might be strange patterns on some ASI294MC Pro stretched images, does this mean the camera is defective?:
NO, it is not a defect, and it is just a characteristic of the sensor. The pattern calibrates out of the light image with proper flat frames. A proper flat frame is a capture using an evenly illuminated light source, dimmed down to achieve an average ADU value of 24,000 (this is up to the user and their setup – recommended the histogram peak at 1/3 to 1/2 from the left, as shown in the figure below), a 5-second exposure, captured with the same gain and focus point as the light frames."   (https://astronomy-imaging-camera.com/product/asi294mc-pro-color/comment-page-6#comments)
There is a good guide to using the ZWO version of this camera at https://www.indilib.org/forum/ccds-dslrs/7402-starters-guide-to-asi294mc-pro.html which describes this issue.
Some other threads and guides:
https://www.youtube.com/watch?v=z_koNt5J1I0
https://forums.sharpcap.co.uk/viewtopic.php?t=5561
The Sensor datasheet at IMX294.zip may be useful.
Give it a try and see if it help. If so, please report that back here.
Roger Nichol:
There is no such recommendation anywhere in the user manual. Do you actually own it?
Tom Boyd avatar
Roger Nichol:
I own the 294MC and collect flats via a flat panel. I routinely collect flats with exposure times of less than a second and observe no issues with the flats produced.
Well Written Concise
Greisy Valdes avatar
Hi! I had posted about this same issue before, I use the zwo294mc pro, and what worked for me was taking flats at around 4-5 seconds. I no longer deal with this issue. If you use NINA to take your flats, my settings are here. These settings got rid of the gradients completely, at least for me. (I use a cheap tracing light pad from amazon to take my flats)
getting somewhere :-)
Roger Nichol avatar
What have you changed?
What's wrong with my filters?
Hi! I'm getting some immense gradients in my final stacked images, which "should not happen" since I have proper Flats. The filters are in an EFW and they look clean (basically placed directly in the EFW straight from purchase). They do...
Gradients in stacked images despite proper flats; similar calibration issue.
Nov 19, 2024
Spikes problem
Hi everybody, I have shot IC63 some days ago (here) and i wonder why is Navi looking like that? I mean, i saw other photos with 4 long spikes on it and mine seems to have a lot of intermediate spikes to the center of the photo (and small ones to the ...
Flat frames can cause diffraction spikes and artifacts in stacked images.
Oct 10, 2021
Pixinsight not using flats when stacking with WBPP - not sure why
Hi everyone. It seems I have a new problem… I have been using PixInsight for quite a while now and I finally got the hang of it. Over the last few days I've noticed that some of my images especially the ones with Ha are not incorporating th...
PixInsight not applying flats during stacking; directly addresses author's problem.
Oct 14, 2024
PixInsight WBPP and calibration frames
I wanted to keep this on the PI forums but my account still waiting for admin approval so here it goes. I use PI and WBPP. as for calibration frames I use masters created from the ASAIR plus. Is this okay to do? might not be ideal I know, but is ther...
PixInsight WBPP calibration frames; relevant to author's stacking and flat issues.
Aug 21, 2024
Trouble with Deep Sky Stacker applying flats correctly
I'm having trouble with stacking photos lately and not sure what changed. I'm seeing dust mote artifacts in stacked & calibrated images that shouldn't be there. Below is an image straight out of DSS. No further editing, STF applied. Y...
Deep Sky Stacker not applying flats correctly; similar flat calibration problem.
Dec 9, 2024
