using L-pro filter with mono L-R-G-B filters together?
6 replies514 views
Yuval avatar
if you want to shoot let's say galaxys from Bortle 7-8 with mono camera and LRGB filters..
what about installing L-pro filter between the filter wheel and scope.. so you can use LRGB filters without too much light polusion?
what you think? possible?…. it will work well?..
It will work to the extent of the LP suppression afforded by the filter in question. Those using OSC cameras do it all the times… Obviously the L filter is pointless since the UV/IR cut function is already performed by the LP filter ahead but you might want to retain it for sake of parafocality with the other filters (and not messing up with the filter wheel).
Michele Campini avatar
I'm using a 2'' IDAS P3 inside mine flattener/reducer and i do not remove it, ever. For L, R, G, B H O S.
At the beginning of "mono" experience i used IDAS P2 (36 mm) only for luminance but too much ofter mine RGB was too bad because the gradients. With the IDAS P3 ever mounted i fixed all my problems.
But i shot from a balcony when object are low in the sky. When i go under clear sky i do not use the IDAS P3 of course.
IDAS P3 is very similar to the Optolong LPro.
Tareq Abdulla avatar
Michele Campini:
I want to see some results from that.
Any halo?
Tareq Abdulla:
Michele Campini:
Any halo?
U can check in my profile.
Some halo of course, but expecially with the FRA500 i've halos without IDAS P3 too.
I personally gave up solving the halo problem because otherwise I would have stopped doing astrophotography.
Michele Campini:
Tareq Abdulla:
Michele Campini:
Any halo?
Ok, i will check out, thank you
Alan Hancox avatar
I used my Lpro as the luminance channel with fantastic results. I was using a zwo 1600 mm pro at the time..
A PSA/Rant/Warning/Opinion on CLS Filters, Light Pollution Filters, and Tri or Quad Bandpass Filters
Summary: These products are misleading in their marketing and do not return a result that is worth your money. This is intended to be a warning message that I'd copy/paste to people considering buying one of these filters, but I figured I'd p...
Discusses light pollution filters and their effectiveness for deep-sky imaging.
Dec 3, 2024
Astronomik Filter Halo Story
This will be long, TLDR: Myself and at least a few other competent imagers have had recent issues with Astronomik Deep Sky RGB filters and Astronomik's customer service. Buyer beware. I will preface this by stating that I am not looking to bash a...
Addresses filter quality issues relevant to RGB filter performance concerns.
Feb 8, 2025
