Blue Halo's(?) Dots left after StarxTerminator Pixinsight
11 replies608 views
AstroNOM avatar
Dear forum,
I'm experiencing some trouble processing a picture. After I use the Starxterminator I'm left with an almost starless picture, and a Star Image. But when I look at my Starless picture I see blue dots almost everywhere where the stars were, and even green ones. When I zoom in to me it looks like small halo's from where the stars used to be.
Her are a few examples from the picture im processing. Is there anyone who could lead me the good way to get rid of these blue spots, or to tell me where I maybe went wrong in the first place?
Much appreciated!
Melvin
jewzaam avatar
These look like halos I get from my l-extreme filter, SXT doesn't remove those either.  I don't think this would change the result, but try extracting each channel then run SXT on each individually.  The way I deal with the l-extreme halos is to repair them in  Affinity Photo using infill painting.  Also you could try stretching less on the stars and see if the halo is more controlled.
Helpful Concise Supportive
If they exist only one channel then paint them over with the nearby background and you'll be done with them once overlaid with them stars back in.
Bob Lockwood avatar
One thing to keep in mind is SXT removes stars, not halos. As far as STX is concerned, the halos are nebulas.
Find out why you are getting halos, could be the filters.
Minh Lết avatar
Use a clone stamp and stamp them out or use spot remover in photoshop
AstroNOM avatar
Thanks so far for the replies, I will get to work with all your input! If any better I will post new pictures.
More input always welcomesmile
Willem Jan Drijfhout avatar
Have you tried BlurXTerminator first with an aggressive setting setting to reduce halos, and then do SXT?
Tim McCollum avatar
Not an ideal solution, but in PI open the color saturation process, hover over the blue while watching the hue line to see where the exact color is, then place a point there. Next place 4 more points, 2 either side of the center point. Adjust the spacing from the center point as a bandwidth setting, open real time preview and drag the center point down to kill the color. You could also make a blue color mask and then using curves kill the blue as well, hech maybe also with the blue mask do SCNR to it.
These are all just work arounds to save the data you have vs figuring out the exact cause of the halos.
Tim
AstroNOM avatar
Willem Jan Drijfhout:
No not yet, but I will definitely try that! Im now trying to perform SXT for all filters seperately before combining the filters into a coloured image. Might help too.
AstroNOM avatar
Tim McCollum:
Tim
Tim McCollum:
Tim
Thanks Tim for your effort. I will have to dive into this one with a bit more time, but will also definitely try your way to see how it goes!
Alan Brunelle avatar
StarXterminator does not always work to perfection.  I get those as well sometimes and sometimes not.
Recommendations to infill or clonestamp the halos out generally work well.  But beware, not always.  The halos, and sometimes partial stars left in the "de-starred" image are part of the information within the complete image.  You can prove that by recombining the star image to untouched, de-starred image and confirm an image faithful to the original.  The implication (and reality) is that in filling and clonestamping to remove the halos and partial stars in the starless image will remove the information that would have completed the image after the stars are returned.  This does not cause big issues in weak halos left in the starless image, and indeed can be a help to removing halos.  But some spikes and partial stars removed can skew the color and the shape of stars after the recombination.  So beware the fixes proposed might required additional work after recombination to fix the issues created in that process.
In my
The Coma Cluster - Added Data - Pushing the Limits with BlurX-, StarX-, and NoiseX-Terminators
  image. StarXterminator left a good number of stars in the starless image.  Some of the biggest and brightest stars.  Very perplexing.  Yet removed many of the very small background galaxies, even the small smudge galaxies that are clearly not round.  So more learning for the AI library needs to be done?  Well, maybe, or maybe not.  The new library works very much better than earlier versions, even on this image.  It just may be that StarXTerminator cannot be expected to do everything.  But if improvements can be had, the Coma Cluster might be a place to teach the AI.
Helpful Insightful Respectful
AstroNOM avatar
Alan Brunelle:
In my
Thanks for your input Alan. I saw your picture and I respect the work that you put into it. Amazing photo! I have to say that for me there is a lot of learning in PixInsight and i still have to develop a solid workflow considering bias frames, pre processing and pos processing. Eventually ill get to the answer of thes problems, the more I learn the better. Thats why, all the input is welcomed and much appreciated!
Respectful Supportive
Astronomik Filter Halo Story
This will be long, TLDR: Myself and at least a few other competent imagers have had recent issues with Astronomik Deep Sky RGB filters and Astronomik's customer service. Buyer beware. I will preface this by stating that I am not looking to bash a...
Filter halos could cause blue/green dots remaining after star removal.
Feb 8, 2025
Artefacts near coma-corrected stars after applying "Correct only" in BlurXterminator
Hello dear AstroBin community, I'm posting this to see whether anyone else encountered this issue after applying the BlurXterminator and whether there is some way to avoid it. Below this post, I've attached four images showing the lower-left ...
BlurXterminator artifacts near stars similar to your post-processing issue.
Oct 24, 2024
PixInsight 1.8.8.7 Manual Update
Hello to everyone, Can anyone help me with the PixInsight 1.8.8.7 update? I'm trying to download her for my OSX and my Windows from the server though my account, but it gives me an error on starting the download. I'm currently in the 1.8.8.5,...
Author uses StarNet++ for starless techniques; similar tool troubleshooting may help.
Mar 24, 2021
