Astro avatar
Hello all,
After finally getting off my but and buying some better equipment I am finally moving closer to targets.
for the first time I finally set up all my new gear last night.
WO Redcat 51
Nikon d5100
Star Adventurer 2i pro
Ioptron SS tripod
And after that first set up now I find myself here in order to get your help on figuring out what I screwed up.
hehehe
so, when I attach the scope I cannot adjust my f stop.  I see “F—“ on my dslr menu.
I tried a Nikkor 50mm lens and I can manually change my f stop but then Redcat back on and I’m back to “F—“
anyone else seen this?
Thoughts, suggestions?
thanks in advance for any help you can provide
Jeremiah
Have you set the Mode Dial to M?
Thomas avatar
The Redcat is a set f/4.9, you won't be able to adjust the f-stop on that scope. You will have to change ISO and shutter speed to make any changes you want. And as mentioned, M-mode is the best to use.
Astro avatar
Andrea/Thomas,
thank you for your responses.
I did indeed have the camera set to manual “M” mode (the second time, hehehe)
Thomas, maybe I’m not understanding correctly. I know the scope is a f4.9 but I should still be able to stop down in my dslr menu right?
either way, the OTA isn’t talking to the camera so I should have to set the dslr to 4.9 so that the camera body is matching the OTA?
sorry for my ignorance, I just haven’t found any articles explaining this and I’m trying to understand how to use an OTA with my dslr.
update:
I just looked up some videos of people using a Redcat and after some careful pausing I got a view of a canon dslr menu that showed “F00” so it seems I really am worried about nothing? (I hope)
thanks again
Jeremiah
Astro:
Andrea/Thomas,
thanks again
Jeremiah
There is nothing you can do except set the exposure time and the ISO (use 200). From the point of view of a DSLR a telescope is just an entirely manual lens.
Thomas avatar
Astro:
Andrea/Thomas,
thanks again
Jeremiah
No, you don't have to match the f-stop in your camera, it will just appear blank. There are no electrical contacts for the camera to talk to the scope so it only sees it as a full manual lens. The stepping down is set in the camera but physically happens in the lens. In this case, since the scope is fixed, no adjustments can take place in terms of f-stop.
Astro avatar
I’ll try that Andrea. Thank you BOTH.
weather permitting I’m going to be in a bortle 3 next weekend so hopefully I can reply back via an Astro image soon.
thanks all,
Jeremiah
Focuser movement on the WIFD
Hey I am setting up my Redcat 51 WIFD, and it seems strange to me the focuser doesn’t seem to have full movement. It’s stops when I get to 23 ish. Anyone else that has the same scope and see similar or different behavior?
Author has Redcat 51 scope; post discusses Redcat 51 focuser issues.
Aug 17, 2024
How to use ZWO ASI 385MC
Hello! I am new to astrophotography and I need a little help getting started. For some reason, when I attach my ZWO ASI 385 to my telescope (I have an Askar 103 APO), I can't see the sky. If I get an object centered in my telescope, (such as the ...
Author cannot adjust camera settings when attaching scope; similar attachment problem.
Feb 2, 2025
