Help Using GeneralisedHyperbolicStretch
9 replies617 views
Zak Jones avatar
Hi all,
I have been having trouble getting good results from using GHS in PixInsight.
Whenever I use it, I seem to wash out my images and lose quite a bit of contrast.
I've tried following many different tutorials online (even one from the authors of GHS) to no avail.
Due to this, I have been using HistogramTransformation most of the time, and sometimes other stretching methods such as ArcsinhStretch or MaskedStretch, and have found that I get much better results from using them instead of GHS.
I might be using GHS wrong, but I want to learn how to properly use it as I have seen many people online get fantastic results with it.
Attached is an image I am working on and the settings I have used after a second stretch using GHS. Some settings have been copied from a tutorial I watched online from Paulyman Astro.
For me, something that is quite noticeable is the nebulae underneath the Carina Nebula. They are quite washed out and don't look "natural", plus the Carina Nebula looks quite washed out as well.
One thing that I do like when I use GHS is how well controlled the stars are, but other than that, I haven't really been happy with my results.
I am hoping that you guys can walk me through some techniques that I can use to implement into my workflow and start using GHS to my advantage.
Lastly, I am not trying to say that GHS is bad, it's just I am having trouble using it properly. It's a fantastic tool and the developers are always helping people out too, so that's an added bonus!
Zak
Respectful Supportive
Mike Cranfield avatar
Hi Zak
For your second a subsequent stretches it can be very helpful to switch to a log view of he histogram (the second button on the left above the graph).  The histogram "hump" (which you have peaking at around 0.2) represents primarily background, the brighter detail in the nebula exists more to the right hand side of the histogram graph but here the histogram values are "squashed" so you cannot really see the profile.  The log view is specifically designed to reveal this detail.
If you switch to a log view on this image I expect the slope to the right of the histogram peak will be downward but quite "bumpy".  Bumps will reflect areas where pixel values have become "bunched".  This will correspond to a lack of contrast in your image.  Your image will likely improve if you set your Symmetry Point at these bumps - set a mid sized Local Intensity and then bring in a bit of Stretch Factor.  You should see the histogram graph gradually becoming more linear, less bumpy, and also see some contrast coming into the corresponding parts of the image.  You may need to do this in a few different places to get a pleasing result.
If things are getting too bright use the Highlight Protection slider to bring overall brightness down a bit.  Alternatively you can use the Shadow Protection slider to stop the background getting too dark.
It is difficult to be too specific because, of course, every image is different and your vision for your image will be personal but hopefully this gives a few more pointers to work with.
Let us know how you get on and any further questions that you have.
CS, Mike
Helpful Insightful Engaging
Zak Jones avatar
Mike Cranfield:
Hi Zak
CS, Mike
Hi Mike,
Firstly, apologies for the extended period of time in between responses, I have had a lot going on in my personal life that made me unfortunately miss out on three months of astrophotography (plus the weather didn't help either).
Thanks for your pointers in using GHS. I have finally figured out how to use GHS properly, mainly thanks to your tips and Adam Block's videos on GHS.
It's a fantastic tool to use, and I have been getting much better results than I used to, especially in bringing out background elements in my images such as nebulae or dust whilst also retaining good details in the stars.
If I find any other issues when using GHS, I will be sure to reach out again, and I will make sure that I actually respond in a timely manner this time!
Zak
Emilio Frangella avatar
Hi Zak,
can you point out which Adam block video are you referring to? I can t find it on yt, is it paywalled on his website? (i have his subscription anyway so i would be able to watch it)
Asking because i have the exact same problem as you, while i seem to be able to extract more faint detail and in general better SNR with GHS, what i dont like that i lose a lot of contrast in brightest areas especially against dark structures
Bruce Donzanti avatar
Emilio
On Adam Block's website, you can find the videos under PI Fundamentals, then click on Stretch Academy.  There are 6 videos demonstrating GHS.
Bruce
Zak Jones:
Mike Cranfield:
Hi Zak
CS, Mike
Hi Mike,
Zak
Hi Zak. I am glad you are managing to get GHS to work for you now. Adam's Stretch Academy series is very helpful - a real nuts and bolts look at the whole stretching landscape!  CS, Mike
Zak Jones avatar
Emilio Frangella:
Hi Zak,
Hi Emilio,
As Bruce said, the videos I watched are on Adam Block's website under his Fundamentals collection.
Highly recommended, love watching his videos. I have learnt so much from him since I subscribed to Fundamentals last year!
Might even go onto Horizons once I feel I am at a level where I can improve my images further.
Zak
Zak Jones avatar
Mike Cranfield:
Zak Jones:
Mike Cranfield:
Hi Zak
CS, Mike
Hi Mike,
Zak
I totally agree with you about Adam's Stretch Academy videos, they are unique and have a lot of information in them!
Looking forward to seeing what else you and Dave have planned for GHS in the future!
Zak
Aris Pope avatar
Bruce Donzanti:
Emilio
Bruce
Is that on the free portion of his site??
Aris Pope:
Bruce Donzanti:
Emilio
Bruce
No- it is on the members only section
Difficulty Regarding Color in Imaging. This is Not Color Choices or Palettes, but Monitor Calibration for Viewing and Also Printing
Hi All, I am curious about any solutions or experiences others might have had with color. I had a recent, and unresolved issue with color reproduction of an image I wanted to print at a commercial outfit. At this outfit, I have had a number of prints...
Jan 22, 2024
Both posts discuss technical challenges with image processing and color reproduction in astrophotography workflows.
