M 1 Crab Nebula expansion animation (2021/2023)
5 replies471 views
Bernd Limburg avatar
i just finished my second image of M 1 almost exactly 2 years after the first one and did a parallel processing of the data to obtain final images that are as identical as possible. Question was: "Can I see any change in the supernova remnant after 2 years?"
Here is the GIF animation of the result:
M1 animation (2021/2023)
In 2 years, I will add a 3rd frame to the GIF!
CS, Bernd
Rob Johnson avatar
Great project Bernd and yes you can definitely see the expansion in your gif, well done! You must have kept to a very strict workflow to keep the images so ‘identical’.
cs, Rob
Respectful Supportive
Oscar H. avatar
I had no idea they expand in size this fast. smile
This is what 15 years of expansion look like:
https://www.astrobin.com/cfse3j/
Biggest surprise is the runaway star to the upper left. Got to check on that one...
Oscar H. avatar
@andrea tasselli
Why is that top left star moving so fast? Only 15 years?
@andrea tasselli
That star is G 100-20, a 12th mag star which has an apparent motion of 0.25"/yr (source). So in 15 years it moves almost 4 arcseconds.
The direction is south, so "downward" in my image (which is north-aligned). In the 2 years between my images it moved 0.5" down, and I think even in my animation this is (barely) visible, if you know it and "want to see it"
Well Written Helpful Insightful Concise Engaging
