Any tips for dealing with gradients in nebulous dense frames
2 replies225 views
Pete Mumbower avatar
Title says it all. Does anyone have any tips or workflows in PI (or elsewhere) for using DBE/ABE to deal with gradients you know are there, but most the frame contains nebula?
Thanks for any help with this.
Pete
Wei-Hao Wang avatar
One way is to do this iteratively.  You can always start with ABE with function degree=1 and a somewhat large standard deviation for rejection.  This will roughly remove the global gradient so you can apply a smaller deviation parameter to better reject nebulas and stars in a subsequent ABE (with higher function degree) or DBE.
If you do the above carefully, you can almost certainly get acceptable results.  To get the best and most accurate gradient removal (demanded by mosaic works), you need to take a wider-field image, like 3 to 5 times wider than your main-scope FoV.  Run a careful ABE/DBE on that image first.  Since it's wide, there should be more nebula-free areas for you to run a robust ABE/DBE.  Then you can use that image as a gradient removal reference for your main image.  The photometric mosaic script in PI can be used for that purpose and it works quite well.
Well written Helpful Insightful
I did a quick ABE application to my Lum master with the Function degree=1 and and the Deviation set to 6.2 and that gave a decent result. I will continue to reiterate as you outlined above, but I think this will work. Thank you very much.
Your second idea for a much wider field image is something I wondered about. I do have a 275mm fl triplet refractor that I plan to piggyback on the 12"f/4 and that would fit the bill. I could image with both setups at the same time to get the gradient data. Very interesting.
PixInsight New Tool - Multiscale Gradient Correction Test
Yesterday a new version of PixInsight 1.9.0 was released. The release contains some nice features, but by far the most important one is the MultiscaleGradientCorrection tool (I): https://www.youtube.com/watch?v=BHE3J069NCo It is supposed to do backgr...
New Multiscale Gradient Correction tool in PixInsight directly addresses gradient correction needs.
Dec 21, 2024
Gradient correction with narrowband
Hi all, Have a quick question here regarding gradient correction with narrowband data!! In my workflow I use the gradient correction tool in PI to sort the background very early on and out of curiosity I check the “Generate gradient model” or whateve...
Gradient correction workflow in PI using gradient correction tool for similar problem.
Aug 8, 2024
Gradient TOOLS compared: GXP, GC, ABE
Good morning, Not pretending to share a deep analysis, just a quick test on some good data that I captured from Bortle Namibian sky last July 2024 (Tivoli Astrofarm). Image details: L = 96x300" (8h) ; FRA300 + ASI2600MM + AM5). I wanted to test ...
Compares gradient tools including GXP, GC, ABE—exactly what author is asking about.
Dec 9, 2024
