Question about LED flat panels
16 replies792 views
Paolo avatar
Hello!
For those of you that are using one of the following flat panel (basically a flat panel available in EU that's NOT and EL panel):
* PLL Giotto
* Artesky
* Pegasus LED
Can the brightness be lowered so that I don't have to stack anything else (t-shirt, paper, etc) when using an f/5 refractor and LRGB filters? I need the exposure to be >=1s on my 268m.
Thanks
Gerassimos Arsenis avatar
Some flat panels allow for adjusting the brightness. I think the Artesky is one of those panels. They are a bit expensive though. I use a Lacerta flat field box that doesn't allow for adjustment.
One thing to keep in mind with flat panels is you might get light leaks. I was getting terrible flats and I didn't know why until I through a towel over the flat panel which apparently covered a leak. So, in the end, you might end up using a t-shirt (or something else) either way is what I'm trying to say.
SoDakAstronomyNut avatar
What size are you looking for? CS & GB! Kip
Paolo avatar
I own a 70mm apo, but I'm also planning to buy a 150mm apo towards the end of the year.
I bought one of these and it works great with my Celestron EdgeHD 8” and Askar 130PHQ 5” refractor.
https://www.adorama.com/vtrvl500t.html?gclid=CjwKCAiA3KefBhByEiwAi2LDHHr0QtUFi-A12S2-JWHNJYEnDUH9TmXpzCX9PjXJezBLt0JTdCzsBhoCNCoQAvD_BwE&gclsrc=aw.ds&utm_source=inc-google-shop-p
10” diameter, rechargeable battery with color and power selectable switch. LED results are flat, no banding or cycling. I was using a tracing led and my flats would vary.
CS & GB.
Kip
Concise
TurtleCat avatar
Many of the LED panels will have banding. I know the Flatmaster will. I have to put several diffusion layers to ensure that the exposure is long enough to even things out. Typically 6+ seconds/flat.
Understood. The item above does not. I also add a t-shirt in an embroidery hoop just to be sure. No issues with my QHY268M PH astrocam.
CS & GB! Kip
Chiradeep Chhaya avatar
@Paolo Have you looked at DeepSkyDad flat panels? Super convenient and fairly reasonably priced. Even have the option of a heater element to keep tube from frosting. Of course it has an ASCOM driver too and works flawlessly under NINA for me. You can control brightness as well as exposure time.
They are located in Slovenia so obtaining them in the EU shouldn’t be an issue. And they are very responsive and helpful.
Cheers!
Well Written Helpful
Paolo avatar
Chiradeep Chhaya:
Cheers!
Good to know, thanks! Wasn't aware of them. I just sent them an email to check some stuff, let's see
Peter Christensen avatar
I can recommend this compact adjustable screen 26 x 37 cm:
PHOTTIX LED LJUS NUADA S3 VLED
which I bought at:
https://aifo.se/svEN/phottix_led_ljus_nuada_s3_vled_video?id=PH81421
at the prize of 78 €
Chris Bailey avatar
Ive got the Pegasus. Works well and NINA flat wizard will control the brightness to give you correctly exposed flats. Also means that if you want, you can control the duration of the flat (say 3 seconds), NINA will adjust the brightness to suite, you can then take a bunch of 3 second flat darks.
Rick Laird avatar
What did you use for the diffusion layer?
Rick Laird avatar
I have the PLL Giotto.
I have used the Pegasus Astro Flat Master. I really don't like the software that runs Pegasus Astro tools.
Rick.
TurtleCat avatar
Rick Laird:
Right now I’m using several layers of printer paper which works very well. I have some photography diffusion material that I’ll cut up eventually once I can get it to be uncurled.
Rick Laird:
Rick.
I agree - even the Unity Platform for PowerBox constantly gives me trouble.
Tim Eriksen avatar
​​​​​​x
on the left is a led trace panel for my RC6 on the right is EL panel for my z81
White T-shirt or sheet only for Flats?
Hi gang, Interesting question at a gathering the other night: A new imager, who uses a light panel for Flats in a home observatory was asking if it was possible to use a darker-colored T-shirt or sheet with a mono CCD camera to acquire her Flats. App...
Directly addresses LED flat panels and brightness issues with different cameras.
Jul 19, 2021
Help with large ring in images
Hello, I have recently started to get this large ring in my images (see below). I believe my flat frames are causing it but I don't know why. I have cleaned my optics thouroughly (filters, coma corrector, mirrors), yet the ring persists - it'...
Flat frame issues may relate to brightness problems with flat panel equipment.
Jan 13, 2025
