Argh - autofocus gone wrong.
9 replies266 views
Piers Palmer avatar
I set up last night with my SD81S, SXD2 mount and ASIair Plus.
M81 was directly overhead, I ran the autofocus facility, set guiding off, and started an Autorun routine consisting of 60x180". Autofocus was set to run every hour.
The first hour seemed to go fine
But then the autofocus routine ran...and failed, giving images like this...
The autofocus tried again an hour later, but then guiding failed too (I quite like this one!).
Finally, the mount didn't even return to the home position.
Autorun_Log_2023-02-12_221439.txt
The log is above - any help, gratefully received!
Marc-Antonio Fischer avatar
Most AF problems are related to backlash problems. Is the focuser tightly mounted? Are the focuslock screws open?  Try you focuser during daytime with full equipment load. Go to a certant focus position, remember or mark the focuser tube,  go at least 200-1000 steps inwards/outwards (depents on focuser model) and then go the same amount backwards. It should be on the excat same position if not there is a backlash problem. Its a lot of try and error until the backlash is finaly right. Had many problems with cheap focuser. Ive got a RC and when its poiting directy in the sky the gravity drags the camera focuser down and the backlash is stronger…. its really annoying
Piers Palmer avatar
Thanks - I'll try that and I did wonder if it was because, pointing straight up, the weight might be causing an issue.
I think I had sorted the backlash, but I'm going to check!
Piers Palmer avatar
Well the backlash seems fine - not sure what's going on there yet, but the guiding issue is sorted….I need a half pillar!
Piers Palmer:
Yes i think thats your main problem, because Ive got it too. Damn gravity 😂 you can try do focus on a other point in the sky were the telskop is not poiting exactly in the sky. But not a long term solition.... new focuser i think it is. You got barrings or tooth ?
Do you use offaxis guding? That would be the reason too that the guding failed when its aslso out of focus
Piers Palmer avatar
Thanks Mark - the focuser is Vixen's standard rack and pinion. It's not high tech but it is strong and robust. What I don't quite get is how the autofocus routine at the 1hr mark, started with a star size of 3.1 and then went from 13.9, down to 3.1 then back up to 10.8. Why would the software do that and give up? That would suggest to me that the weight wasn't an issue but it seems odd that it's worked fine before now.
No OAG for me, just a normal guide scope. I think I'd hit the tripod legs though so that one is easily explained!
These HRF values seem fine to me. They fit the parabolic pattern. Main problem i guess is driving the focuser back to the lowest value at 3.1 from 10.8.. and this is most likely backlash… but you said you fixed it. Another tip. AF every hour is way too much imo. After a flip i enouth. At least with my equipment…
Piers Palmer avatar
You make a good point - this is the first time I've ever set it up to focus every hour…and look what happens!
I'll have a play with the backlash again this afternoon and have another go tonight with an autorun routine.
Piers Palmer:
You make a good point - this is the first time I've ever set it up to focus every hour...and look what happens!
Good luck my friend. Never surrender
Question regarding frequent Autofocusing: Isn't it just wasting a lot of time?
I do use an auto-focuser (Sesto Senso 2), but after the initial auto focus before any sequence, I don't. The reason is, because it takes forever. 10 minutes or more sometimes. It just keeps moving the focuser up to like 24 points until it finally...
Covers autofocus problems and troubleshooting with specific equipment setups.
Jul 23, 2021
Adapting the 585MC Pro to a Rokinon 135mm w/ Sony E Mount
Hi all! Having shot exclusively with a Sony a6100 and using a Rokinon 135mm F2 ED UMC for the past year, I have finally made the jump to my first dedicated astro-camera, the ZWO ASI 585MC Pro. I was mostly sold by the great comments from Cuiv and Luk...
Discusses camera adapter setup; may help troubleshoot imaging chain issues.
Oct 29, 2024
