Cleaning Inside of Celestron Edge 8 Corrector Plate
3 replies260 views
Jerry Gerber avatar
At some point I am going to want to clean the corrector plate on both sides.   Does anyone have experience removing this plate on the Edge 8, cleaning it and placing it back correctly?
I would rather learn how to do this than send the telescope back to Celestron and wait weeks to get it back.
I've watched some videos on You Tube, but none give me any confidence that the people making the videos know what they are doing.
Jerry
Well written Engaging
jeffreycymmer avatar
I did it on my Edge14 so it should be similar.
Remove the retaining ring.
Remove the secondary.  It is keyed so no problems with re-assembly.
Place a small piece of tape on the edge of the corrector plate and the corresponding inside of the scope for alignment when re-assembling.
There should be set screws around outside of the scope that hold the corrector in.  Loosen.  The corrector should come right out.
Check this website:  http://arksky.org/aso-guides/aso-general-guides/23-aso-fine-optics-cleaning-system for the best cleaning solution ever.
Jeff
Jerry Gerber avatar
Jerry Gerber:
Jerry
Thanks Jeffrey.  But I do have one question:  Why remove the secondary when the corrector plate (with secondary) comes off in one piece?  Wouldn't it be better to use the secondary as a grip to hold the corrector plate while removing and replacing?
The secondary mirror requires different cleaning methods since it is a first surface mirror.  Its best to clean each piece separately.
Any idea why celestron's been making new telescopes, but no new equipment for those telescopes?
Hi guys, I've been in search of a .7x reducer for my Edge HD 8 for a while, and I noticed that celestron's been making and shipping new full scope packages, but ZERO new accessories like reducers, and T-adapters for them. Any clue whats going...
Directly addresses Edge HD 8 maintenance and component access issues.
Feb 23, 2021
Gear advice
Hello, Please feel free to let me know if this topic is in the wrong area… but I have the 9.25" EdgeHD. I have been using it for a few months now, primarily for visual work and just learning the scope and mount. In the time that I have had...
Discusses EdgeHD telescope model; may contain relevant maintenance or ownership information.
Dec 16, 2024
