LRGB Colour Calibration in Pixinsight
3 replies383 views
IrishAstro4484 avatar
Getting the colour right in LRGB images is a bit of a dark art imho so I'd be interested to hear any thoughts on best practices or useful tips and tricks.
Obviously you can look at other published images for guidance but I always do that with caution.
Any thoughts would be much appreciated.
Pistachio_Enjoyer avatar
Try SPCC. To use it first, you'll need to download the Gaia data from the PI website. Then after setting Gaia to read from a set directory, ensure that your image has a correct solution (i.e. its plate solved, you can use image solver for this). Then in SPCC, you can enter your sensor's QE curve (its a drop-down list of selections), your filters, etc.
*** Thank you. I'll definitely try that ***
jewzaam avatar
+1 to SPCC, don't dismiss PCC though.  I've had at least one data set (older) where SPCC wasn't happy with it but PCC had no issue.
You mention LRGB, generally you'll run SPCC/PCC on the RGB image while linear.  If you have L this is best combined after color correction and after stretching.  Not sure what all apps call it, but in PixInsight you'd use LRGBCombination process.  And if you didn't capture L specifically you can extract L and use that instead.  It's better than _not_ doing LRGBC at all in my opinion smile
Tips for Dark Nebula Processing - LRGB
I would love advice/guidance on how to make the best of only one night of shooting LRGB data of a dark nebula in a Bortle 1 sky with some moonlight/noise. The target was Barnard 150 (seahorse nebula) Firstly, I’m sure that having more data would impr...
Directly addresses LRGB processing techniques and color management best practices.
Sep 19, 2024
Deep Sky Stacker: Getting the Most Out of It
DeepSkyStacker (DSS), a fantastic tool for astrophotographers. I've been using it for a while now, and while it's incredibly powerful, I've also run into a few quirks and challenges along the way. Do you still think that this stacking sof...
Relevant tool for LRGB workflow, though focuses on stacking rather than color.
Nov 12, 2024
M33. Should there be any green in the image at all?
Especially since the introduction of SPCC colour calibration into PixInsight I have given up using colour noise reduction tools to remove green pixels from images – because it ought to be unnecessary and will only alter the colour balance. Howe...
Discusses color calibration and correction methods applicable to LRGB processing.
Jan 7, 2025
