New antlia sii and h beta 5nm filter. Useful?
10 replies730 views
Anderl avatar
Titel says it all.
would love to get an oiii sii dn filter but i am not sure if the sii h beta combination is that useful for deep sky photography.
any opinions on that filter?
Michael Ring avatar
I wish they would have gone for the oiii/Sii combination as Askar did because this better matches my approach with OSC.
For me problem is to get acceptable Oiii and when not able to get acceptable Oiii because of the moon then at least a lot of it.
I currently do not see a plus point in getting lightpolluted Hb that is in addition not as intense as Ha, I get more of something that I already have so there is not much point in that.
Maybe it makes more sense for mono shooters as luminance but I do not know if there is enough signal in Hb for that usecase.
Michael
H-beta IS NOT H-alpha, as some seem to think.
Anderl avatar
yes, of course.
and still the question remains, can a astrophotographer profit from getting h-beta?
I just don't get why antlia decided to make that filter. every osc photographer I know is waiting for a usable oiii + sii filter.
yes, of course.
Only if you don't follow the usual trodden path. I can see how I would use such a filter in my workflow.
Tim Hawkes avatar
Intriguing comment  and a bit of a challenge there Andrea   --   the usual paths are sometimes well trodden for a good reason  --so tried here  to further think through your proposition that the H beta filter could be useful  ?
Firstly  yet to see an example  where imaging for example a type II region with an H beta filter has been used except where the point of interest was itself to measure the exact ratio of H alpha to H beta in different parts of  the region ?   Or is there H beta imaging stuff out there that I'm just missing?
On the face of it such apparent under use of the HB filter  by the wider astro-imaging community over so many years would seem to indicate a problem  - or  likely a fundamental limitation in what the filter can offer?
So back to the basic physics - for normal HII regions at temperatures of 10-20000 K  the H alpha signal will be ~ 2.8 x  the  intensity of the H beta signal.   That is fixed by the fact that n =3 --> 2   Balmer transitions are are a fixed amount more probable than are n =4 --> 2 transitions under the given conditions.
However -  this ratio of H alpha to H beta  in such an HII region can increase  (but not decrease)  - up to a value of about 4  (or so I  have read).  This increase  is according to density  differences  in scattering  dust  where the H beta is naturally  scattered more than the H alpha.      So between  different HII nebulae and also within different regions of the same nebula one might expect  to see  differences in images of  - for example - purple shading according to red HA/ blue HB ratio differences of between ~ 3 to 1 and 4 to 1  ?
That kind of level of colour differentiation might well be visible if your image was simply a dual narrow filter image with just H alpha  versus H beta of some type II region  - and also if the effect was not obscured by tonal variation  (i.e  you would  expect the darker tone denser regions to always be the redder)?  HA v HB  might be an interesting way of imaging  type II region density  -- but I'd argue that we get plenty of cues to the presence of dust/ scattering/ density  anyway just in the course of normal imaging  (i.e  denser dust regions look darker and redder just in the normal course of RGB , RGB HA etc imaging of type II regions anyway)?
So I can see H alpha/ H beta  as a specialized interest perhaps but struggle to see how H beta could be usefully combined into or add to the other types of imaging.  Or you could argue that it is included in images anyway just in the course of broadband and broad UHC type filter imaging?
So e.g.  if you were to combine the HB image into a triple -  HA, HB and  OIII - how would that work in practice?   The OIII in HA regions normally needs stretching up anyway so OIII plus HA overlaps will look the same as variations in Ha/ HB ?
Part of the real problem with HB I think is that - unlike OII, NII and SII it does not have the potential to add any completely new feature to any image over HA - it will always be spatially exactly coincident with the HA and always dominated by it.  It only has the potential to make red areas slightly more purply for example -- in a world where NB colours  are all rather virtual anyway and nothing that you could really see because they are not dense enough.    To me the potential to differentiate 3-1 versus 4-1 differences colour differences would never be worth the imaging time.
H beta is a useful filter for visual use to spot HII regions because  of the limited ability of the human eye to see deep red at night.   But for me -- depending on the object and its temperature etc -- I am going to continue simply imaging in H alpha  and -  if it is a pure NB  OOH or SHO type image - using the Halpha to calculate the approximate implicit H beta signal  - of about a third for an HII region - not exactly correct but good enough - to then  add into the blue channel .
Tim
Helpful Insightful Respectful
Tim,
I wasn't thinking about HII regions, at all. And whether the Hb and Ha regions are actually coincident, I doubt it is a foregone conclusion. Do you have an Hb filter? Because I do and I have used in the past with satisfactory results.
TurtleCat avatar
I was initially attracted to the idea of this filter as I have the L-Ultimate that I enjoy using and thought about having the SII data for a Hubble palette. But as I continue to think about it and the time required on target to use L-Ultimate and a filter like this I realized I would rather just go mono instead and get full data. It feels like it would be less work to get emission separations and such. But since I already have a 2600mc and the L-Ultimate I am just going to stick with that combo.
Tim Hawkes avatar
yes, of course.
Hi Andi,  Is it certain that this Antlia filter is really intended for dual wavelength imaging at all?  It would seem to make more sense as partly a visual filter  -with the  bluish light from Hbeta  being useful for visual use -  and the  red SII part only  useful when imaging  perhaps?
Anderl avatar
Tim Hawkes:
yes, of course.
reading the information on the sellers sites it is aimed at visual astronomers as well as at photographers.
but well, world isn’t turning around me (german saying), so it doesn’t matter at all that i am not happy with that decision by antlia.
still hope that the next filter we will see from antlia will be oiii + sii.
Tim Hawkes avatar
I personally think that you are  quite correct here and particularly if you are interested in SHO rather than just OOH NB.  The SII is often the limiting signal in these images and takes long enough with a mono camera  let alone an OSC  which would mean  imaging for ~ 4x as long to achieve the same  image quality in terms of both resolution  and SNR.  This recent thread may be useful on this topic https://www.astrobin.com/forum/c/astrophotography/deep-sky/dual-narrowband-filterosc-vs-hao3-filtersmono-comparison/.    If you go down as far as the bottom of page 5  there is an experiment that I posted that illustrates the exposure time/ resolution tradeoff for HA imaging using an OSC versus a MONO - which accords with theoretical expectations  -- and exactly the same would apply to SII  as to HA.   The HA/ OIII dual filters  plus OSC make pretty good sense for many OOH objects but when you try to add in SII as well  then the mono option looks much more sensible.
Helpful Insightful
A PSA/Rant/Warning/Opinion on CLS Filters, Light Pollution Filters, and Tri or Quad Bandpass Filters
Summary: These products are misleading in their marketing and do not return a result that is worth your money. This is intended to be a warning message that I'd copy/paste to people considering buying one of these filters, but I figured I'd p...
Discusses narrowband filter utility and value for deep sky astrophotography.
Dec 3, 2024
Do you zap the green in SHO pictures?
Hello dear Astropeeps, I am still rather new to the SHO palette with a mono-camera and I just completed my third image on the North American Nebula and never collected as much data for an image as of now. I love to see the separation of gases and how...
Addresses SHO palette imaging, related to narrowband filter combinations.
Aug 2, 2024
Do you experience halos with your imaging setup?
Hello, I got the Baader SHO Ultra-Narrowband Set second hand with a good discount and already had some clear skies to test them out extensively (including NINA's automatised filter offset calculation). After that I did some 600 and 900 second tes...
Reviews Baader SHO narrowband filters, relevant to filter selection decisions.
Sep 23, 2024
Ha 5nm vs 3nm and the missing NII signal. Any examples?
I am looking at getting new 50mm narrowband filters. I was looking at Chroma Ha 5nm vs 3nm filters. Cost is not an issue, but I have read on multiple occasions that the 3nm filters will miss the NII bandpass details in certain planetary nebulae. Does...
Compares narrowband filter specifications, directly relevant to filter choice evaluation.
Sep 19, 2024
