Photographing the comet, need help
11 replies634 views
Daniel Renner avatar
Tomorrow is the only day I can photograph the ztf comet and it will also be the first time imaging a comet.
I use a mono camera (1600mm pro) with my esprit 100 edt and I wonder how long my sub length should be to being able to align each channel? Do I use LRGB or should I only use RGB?
Do people use mono cameras to photograph comets with good reault or is it better to use a color camera?
I have a canon 6d that could be used if it's needed. (but I haven't tried it with my setup yet)
Nadir Astro avatar
Hi Daniel. I recently used FSQ-106 with a mono camera to image this comet. Scope focal length is similar to your Esprit 100, so depending on the pixel size of your camera and resolution per pixel you can calculate the length of your subs.
Current sky motion of this comet is around 10" / min. You can always check the latest ephemerides on MPC website:
https://minorplanetcenter.net/iau/MPEph/MPEph.html
I used only RGB without L on this comet and my subs were 60 sec long, but that was few days ago when it was much slower (relative to us, ofc). You can also use your 6D, but if you'll have just 1 chance to shoot it - it's better to use the system that you're already familiar with instead of experimenting with something new.
Clear skies to you
Helpful Concise Supportive
jewzaam avatar
I've been shooting mono on a 6" newtonian @ f/4.75.  My camera is the ASI2600MM.  I usually shot 2 min RGB subs and 30 second L for DSO in RGB at gain=0.  I have done that with the comet but that was back when it was moving slower:  https://www.astrobin.com/9yj2sx/F/
I have switched to gain=100 (UHC) and faster exposures.  RGB=30s and L=10s.  I have yet to process to a finished image but preliminary pre-processing looks good.  You'll get star residuals no matter what you do (assuming you're trying to remove stars).  My theory is the shorter L will result in less comet elongation and still result in a good luminescence stack.  I'm keen on capturing ion tails, getting more B would be an alternative to L I guess.
Stephan Linhart avatar
Good question, I have only used color cams for my comet pictures.
I suspect the post processing will be more complex with the mono, but should yield better results, if all goes well.
Normally you only have a relatively small time frame, also because details from the comet will be smeared as the structures change over time. Here you might have an advantage with a one shot color cam as less time is needed.
If you go color, practice before if you can, so you know it's working under real sky.
Stephan
Christian Koll avatar
Daniel,
I will try to capture the comet tonight- I am using an Esprit 100 and a QHY600 mono.
From the actual motion of the comet (0.16“ per second) I calculated 60 sec for R, G, B and 30 sec for L.
CS and good luck!
Chris
Jonathan W MacCollum avatar
For this comet, because of all the excitement in the Ion tail, I've intentionally been shooting more Luminance than I typically would.  It's produced some pretty amazing views for animations.  So, I've been looping 30s L,R,L,G,L,B exposures with my newt (.8"/px image scale.)  Still enough information to get a decent color imagebut with the details that happen at smaller scales.
Helpful Insightful Concise
Boris Emchenko avatar
Daniel Renner:
Dear Daniel,
Color camera is a bit superior to mono in comet shooting,  but mono camera is also OK.
I would recommend to shoot only R G B filters (without L) in sequence R-G-B-R-G-B-R-... thus maximizing comet (or stars when comet aligned) travel distance between two images of the same filter. This would greatly help in post processing (sigma clipping during integration).
Regarding exposure - you have to keep comet shifting reasonably low - may be just a few pixels. On your setup with ~1.4 arcsec per pixel I would recommend to try 60 sec or 90 sec maximum.
Helpful Insightful Respectful
jewzaam avatar
Jonathan W MacCollum:
Similar here but L=10s, RGB=30s so:  LLLRLLLGLLLB
Once I get some time we'll see how it goes!
Nice! Looking forward to seeing your results!
Boris Emchenko:
Daniel Renner:
Dear Daniel,
*** thank you! I will try mono tonight, let's hope I can do it with good results 😊***
Daniel,
I was successful yesterday night:
With my pixel scale of 1.4"/px (same as yours) my 60 second exposures in R, G and B, as well as the 30 second exposures in L worked out great.
In total I took 40 frames RGB each and 160 frames L yesterday, totalling approx. 4 hours.
As I posted yesterday, the comet is currently moving at 0.16“ per second.
This means, during a 30-second exposure the nucleus moves accross 3.5 pixels.
A 60-second exposure will cover 7 pixels.
However, nucleus and coma are so bright that you really don't see that.
I have no finished picture yet but - spoiler - the comet currently shows an anti-tail towards the sun.
CS & good luck!
Chris
Christian Koll:
Daniel,
CS & good luck!
Chris
*** thank you! I might go in the middle and shoot 45sec rgb subs and 30sec lum😁***
