Robert Q. Kimball avatar
I just purchased a 200mm Kokina lens at an estate sale for $50, purchased a custom made adapter from Precision Parts, and screwed it on my Atik 383 OSC camera.  It comes to focus which is great.  I also purchased a Pegasus Focuscube v2 and the gears and timimg belts to add autofocusing with Sequence Generator Pro. If anyone has been down this path, I'd love to here from them.. I am especiaslly interested in whether anyone has used a Tokina lens.
Bob
Michael Donaldson avatar
How do you connect your setup to your mount?
Hello Michael,
I'm a woodworker so I build most of my "toys" out of wood.  Actually it a great material, light, strong and very little thermal expansion/contraction.
Here is my rough setup.  I had it outside to see if it would indeed work.  It did.  I am going to give the wood several coats of black paint then screw a dovetail plate to the bottom..  I have the focuser on the right, and ultimately a guide scope on the left.
Camera
Bob
Tele Vue NP127is real backfocuse and space for equipment
In TV-NP127is documentation I found following line "To start, you need to know the distance from the chip to the faceplate of the camera. This should be specified in the camera’s documentation; call your camera’s manufacturer if it is not. The e...
Discusses back focus distance and equipment spacing, relevant to lens adapter setup.
Feb 12, 2021
