Jason Cropper avatar
Anyone here adjusted the prism of the PA SCOPS OAG?  I’m hesitant to touch it. I’ve loosened the set screw, but not sure how to move the prism.
Shouldn’t I use another tool to move the prism up or down?   Any tips would be appreciated.
Thanks,
Jason
Well written Engaging
Matt Nudi avatar
Jason,
For me, I have adjusted the prism height on my Scops OAG, but one thing to note is that there are two set screws on the side, and the one that actually releases the prism may not be the one you initially adjusted.
For adjustment, I did it with the image train disassembled while able to look down the scope towards the sensor and adjust the height accordingly to minimize vignetting. I just used my hands to adjust the height. Once you loosen the appropriate set screw it’s very easy to adjust the height.
Ok, thanks Matt.  I adjusted the correct set screw, but I didn't want to move the prism with my hands until I confirmed that was viable.  I am in the same boat as you.  I have disassembled the image train at the OAG.  I'll move the prism manually.
If only the prism was on a motor!
Again, thanks for your advice, Matt.
-jason
Respectful Supportive
Custom M54 tilt adapter to suit QHY CFW3M-SR & OAG-M system, fits within 55mm BF - Design Files Included!
Hello all. I have a QHY 294M-Pro, CFW3M-SR, and OAG-M fitted to my Vixen R200SS newt. I have been battling tilt with my 294M ever since I bought it, and have been stumped by the lack of suitable tilt adjusters available on the market (especially in M...
Discusses OAG system adjustment and alignment issues with optical equipment.
Jan 1, 2025
