Arny:
Roy Hagen:
I´ve never tried to run separate filters so I am not the expert to answer your question. I guess a mono camera would be more effective for that setup as it has no Bayer filter.
A friend of mine suggested that I should try a filter wheel and several narrowband filters as you thought of, but then, in my mind, the imaging will grow to be lot more complex.
I fully agree that "simpler is better", thats why I go with a Color Cam -
but you're touching something I can't get my head around:
- why does Bayer matrix of a color cam makes it less efeective?
I figured binning the color pixels would create similar mono "super"pixels which are more sensitive - but of course I loose details, ok.
Is there that wrong thinking?
- "imaging will grow to be a lot more complex" means, that taking 3x images for SHO is more complex?
or is there more to it I don't oversee?
Still I am not an expert, Arny.
Just a simple imager.
But if what I´ve understood is correct, the Bayer filter effective blocks certain wavelengths as S an Ha is red it would be blocked by green and blue, Hb and OIII is close to blue and green, so a red filter would more or less stop them. In a mono camera all pixels would collect those wavelengths.
And yes, in my mind, taking three images is more complex than one, or at least, as I see it.
Three sets of flats and dark flats, filterwheel, taking different sets of images over several nights where I live, with weather changes in minutes and three different possibilities to mess up.
This friend of mine, who is a mono imager, talks more often now about OSC and it`s advantages because he is a little fed up of the complex imaging process.
Well, in the end it pays off to do imaging the "complex" way as we rarely find OSC imagers among the IOTD winners.
This is only to clarify my thoughts and not a scientific approach, that would take experts like john Hayes and others.
