Gain/Offset settings
ToupTek and rebranded cameras 2 replies120 views
Tareq Abdulla avatar
Hi all,
Thank you very much for posting your images from this brand of cameras, i appreciate it, and i hope i can get images with mine too, and see more and more images posted here.
So, what is the settings as Gain and Offset you settled on so far?
A. For Broadbanding in LCG and HCG modes
B. For Narrowbanding in LCG and HCG modes
Gernot Schreider avatar
Hi Tareq,
gain and offset setting are camera-specific and depends also on the temperature you are setting, therefore I recommend to do a sensor analysis with your camera to find out the optimal settings for your targeted usage.
I did use SharpCap Pro, which provides a sensor analysis feature for this purpose.
I have a RisingCam ATR3-1700KPAcamera. Below is a sensor analysis in HCG mode at 0°C, offset 0, which I did with SharpCap.
You can set the gain values to do a fine grain analysis but you need to apply some trick in order to convince SharpCap to use these values during the analysis.
You have to enter the below script commands to add additional gain values, which are then used for the next sensor analysis run.
I operate my camera in HGC mode at 0°C with offset 0 and gain 178 for OSC imaging of deep-sky objects.
Hope this helps
Gernot
Hi Gernot,
I didn't reply since last year as i was very busy and also very troubles with situations, but i did read this reply from you, thank you and very appreciated!
I will try to make the analysis with my camera, but i feel like i prefer others to answer with their settings so it can be like a start point or reference for me and others, if we are having very similar setup and conditions i don't see why the settings will be very very different, also with this kind of analysis i am not good in reading the results and then do the settings or decisions according to that, but it is a good point to make it and then know things better, maybe i can keep those analysis results as reference just in case, i didn't make any imaging since really long time and i have enough good equipment while others already did a lot in years, but now once i am back hopefully very soon then i will try to collect data in one year that is almost equivalent of others years collected data, because i have clear sky most of the year which will help a lot, also with like multiple setup it will be like i do 4 in 1 or 4x to what others did, let's see how it will turn out.
Tareq
Touptek 585 c Offset doesnt work?
Hey guys. I am a proud new owner of the Touptek atr585c camera. However, I was testing it tonight and when using the HDR mode with few different settings for Gain and Offset, it seems to be too noisy. Also the Offset doesn't work, whatever the va...
Discusses Touptek camera settings including offset and HDR mode configurations.
Dec 18, 2024
Full Sensor Analysis Touptek ATR2600 mono (IMX571) all possible gain mode + options (HCG/LCG/Low Noise/High Full Well)
Hi, I wanted to share with this forum the sensor analysis I have done on my Touptek ATR2600 mono. My main goal was to see how the 2 options Low Noise ( I will call it LN) and the High Full Well (I will call it HFL) impact the two gain modes HCG and L...
Detailed sensor analysis of Touptek camera with gain modes HCG/LCG comparison.
Dec 15, 2024
IMX571 ToupTek 2600mm settings and slightly bright bottom edge in darks
Hey follow astronomers, As the non rebranded version of this Touptek camera seems to be much more popular than the TS-Optics version I just ordered, I allow myself to post this in this dedicated forum too. So, I just went ahead with a the TS2600MP mo...
Addresses Touptek IMX571 camera settings and gain/offset optimization.
Nov 11, 2024
POLL: What mode, gain and offset do you use?
hello folks I have the previous version QHY600 and I also have the Astrodon I-series LRGB as well as Antilia Ha 3nm. I would like to know what everyone is using for setting? I am using it with an OOUK AG16 F/3.8 newtonian. Thanks so much for your inp...
Poll about gain and offset settings across different camera modes.
Nov 15, 2024
