ZWO AM5, ASI AIR Plus: Polar Alignment
1 reply454 views
Timothy Prospero avatar
Just a question:
when I'm doing the polar alignment with the AM5 using the ASI AIR plus, using the All Sky procedure, I noted that the AM5 is not tracking.
I was thinking that after the third picture and after plate solved the mount should track?! Something not correct? If I goes into the mount setting the tracking is off and if im turning on it will automatically switch off..
Someone else has the same?
Thanks and CS
James (Jim) Poulette avatar
In the even you have not seen them, I  really like Peter's tutorials.
I've never tried "All Sky PA" but I may give it a shot.
Good luck !
https://www.youtube.com/watch?v=QP2Z32e5ZcI
Solving Issues During Polar Alignment
Recently I have been having sporadic issues during Polar Alignment in the AA+. It will often see XXX number of stars but fail to solve and move on. If I cancel and retry sometimes it will carry on and sometimes not. Change exposure try again, sometim...
Polar alignment solving issues with similar mount and software setup.
Aug 28, 2024
Polar align EQM-35, asiair problem
Hey everyone, after several attempts to figure out why I keep getting star trails and what's wrong with my alignment, I’ve decided to ask for help here. I’m trying to polar align my EQM-35 mount using ASIAIR. First, I manually aligned it using th...
Directly addresses polar alignment problems with ASI AIR and tracking issues.
Dec 21, 2024
