Ian avatar
I have two sets Oxygen III data for the Squid Nebula.  One is 8 hours of data and the one below is 12 hours.  The data with 8 hours calibrates well.  I only have been taking flats and darks.  I have tried calibrating and stacking the data below in both APP and DSS.  I get the same results.  I've also calibrated the data using master flats and darks.  The stacked image below is what I wind up with every time.  This is the only data set to ever do this.  I kept my telescope and optical train on a pier outside during the summer.  I never removed the optical train and I have multiple different sets of flats.  I have tried them all and keep getting this result.  It looks as if the flats are mirrored somehow.  Has anyone ever seen this before?  Thanks in advance.
Oscar H. avatar
Check if you have dust on your filter or camera sensor, that can cause the circles. About the mirroring, I don't know how to fix that.
Pete Bouras avatar
The top view of the flat indicates 64 bit. The data coming off the camera is 16 bit.
Perhaps the software does not work correctly with 64 bit data, or mixed bit depth data.
Try 16 bit flats, and 16 bit lights and see if the flats work properly.
Well Written Helpful Concise
Andreas Zeinert avatar
Well, you can easily get mirrors when your Flats, Darks are not done with the same program as your lights. I experienced this some years ago when I switched to Sequence Generator Pro to do my lights during the night but after the nights I continued to do my lights and darks with the genuine Atik program. This resulted in vertical mirrors and it took me a while to understand it as my optical train was not changed. This comes from the coding in the programs who will produce Fits files in various ways (in respect with columns and lines). You might check this if you use APP and DSS on the same time. Hope this helps.
Helpful Concise Supportive
[RCC] Strange artifacts in long exposure image
Not sure if this is the right place to post an image which is giving me a headache. I have recently started to take longer exposures because my object, SH2-129, is very weak in OIII. Here is my equipment: Takahashi Epsilon 130DASI 6200MM camera with ...
OIII narrowband data processing; similar filter and calibration concerns.
Sep 4, 2021
