How to best focus on the Moon?
10 replies481 views
Arny avatar
I have never managed to get a really satisfying focus when taking images of the moon, as seiing disturbs the focus.
Obviously most tools that help to focus on stars don't help on a moon surface like Bathinov masks, or autofocus routines from Nina or AisAir, including contrast driven routines like the NINA beta version or sharpcap.
Of course I tried to focus on stars and then just use that on the moon, which makes sense from theory being both infinitely far away from an optics standpoint. But I always had the feeling that I could get more focus by focussing on the moon and that the edges needed a different focus point than the craters.
So, which best practices and recommendations on how to get the best focus set on the moon would you have?
If you do fine-focus on the stars and then switch to the Moon the latter isn't going in perfect focus and vice-versa. There isn't a trick per-se but it is easier to get a sharp focus on the Moon's edge and then switch to a crater.
Arny avatar
thanks for confirming, that star ocus unequal moon focus :-)
is there any good software support to focus that you have used successfully?
No  that I know of. Your eyes should be your guide.
Wouter D'hoye avatar
The best way for me is to focus on subtle detail in crater walls. Like terasses, ridges etc. When they constantly pop in and out of focus due to seeing then you are in focus. The worse the seeing appears during focusing the closer you are.
One thing that make’s focusing considerably easier is an electronic focus motor. This will r’duce the shake you introduce when touching the focuser.
Wouter
Concise
Michael Kohl avatar
The focus should " popping ", as it was already written above. If that doesn't happen, the seeing is too bad for shooting anyway.
A 1/10 micro focuser is also helpful.
Micha
Andy Wray avatar
The moon should be one of the easiest things to focus on ... I tend to do it manually.  Also, it is so bright that you can use really short exposures on it (maybe 1/10th of a second through a narrowband filter or even 160th second with no filter at all).  Here's a simple moon capture at 0.12 secs exposure.
Moon Feb 10th 2022
Well Written Helpful Concise
Arny avatar
Andy Wray:
Moon Feb 10th 2022
that is good advice - never thought of that - ambarrassing :-)
BTW: great "snap shot" - how much of the cristal clear sharpness magic is driven by the Ha filter?
Arny avatar
Wouter D'hoye:
Wouter
great idea -  thank you!
Never thought of using the popping to my advantage
PS: I did get a motor focus to at eliminate the wobble of my hand touching the scope ...
Andy Wray avatar
Arny:
Not really that much.  here is a bunch of shots I took with an old mirrorless camera with no filters that ended up quite similar:
Moon -- quick stitch of 30 shots on Sony NEX 5N through Skywatcher 200 PDS
Andy Wray avatar
and FWIW:  the photo below was just a handheld photo using a zoom lense on my everyday camera. ISO 100 1/640th sec, Sony 70-350mm F4.5-6.3 G.
How to get stars with a plus sign.
I have a potentially dumb question. I see all these images of sharp stars with light rays making a plus sign. Any pointers on whether this is post processing or acquisition? how does one manage to work towards that? appreciate the help and points. -T...
Focuses on achieving sharp star focus, relevant to star sharpness question.
Jul 28, 2021
Focus issue or collimation issue?
I am setting up an AG Optical 12.5" iHW (f/3.9 Harmer Wynne design at roughly 1250mm focal length) and I am shooting with a QHY600 along with Chroma filters. I noticed that some nights I get these nice rings around stars on the RGB filters. Some...
Addresses focus and collimation issues with large aperture telescopes and cameras.
Aug 26, 2024
possible tilt problem Skywatcher 250PDS
Hi Guys! I hope you can help me with my problem on my Newtonian… Short explanation of my Equipment: - ZWO ASI 294MC Pro - Skywatcher Explorer 250PDS - Skywatcher EQ6-R Pro - ZWO ASI AIR - ZWO EAF I used this combo to photograph C27. The mount w...
Discusses potential optical alignment problems affecting image quality and focus.
Oct 24, 2024
