Autoguiding question for an AVX mount
7 replies459 views
Oscar H. avatar
I have a 1000mm Newtonian on an AVX mount, and a EOS R5 camera.
Is autoguiding strictly necessary when first starting out in astrophotography with an AVX mount (and with such a long focal length)?
If you keep your exposures short and you are very good with your polar alignment you won't need autoguiding. Obviously how long they need be depends also on the position of the object you're imaging in the sky and how well the mount tracks.
Oscar H. avatar
Okay. I think experimenting with the exposure time is the best choice for me then. Thank you.
Jim Raskett avatar
It can depend on the copy of mount you  have.
I know several folks using the AVX and they are not all the same (as are many mass-produced Chinese mounts).
I used to own an AVX (my first mount) and started imaging with a 714 focal length refractor. I PA’ed well (Sharpcap) and limited exposure to 30-45 seconds. Still I had to toss about 40% of the frames due to horrible star trailing, probably due to stiction (they all had trailing, but 40% were completely unusable).
I started guiding and it made a world of difference. I could increase exposure time to several minutes and didn’t have to toss many frames. Never got great stars, but they were acceptable enough for my experience level.
You might get decent enough tracking using short exposures at 1000mm without guiding, but you will have to see how well your mount performs.
If you have a large number of unusable frames, there is a good chance that guiding will help.
Jim
Oscar H. avatar
Jim
I will test it.
If it doesn't work out for me, I was thinking of buying an ASIAIR mini with an orion starshoot autoguider and scope
https://www.telescope.com/Orion-StarShoot-AutoGuider-amp-60mm-Guide-Scope-Package/itemGUID/711d4a7bb49d4c9294576da200ad0a16/p/115000.uts
What do you think?
Jim Raskett avatar
Check out this by Agena Astroproducts concerning attoguiding.
https://agenaastro.com/articles/guides/selecting-a-guide-scope-and-autoguiding-camera-for-astrophotography.html
The Orion package should work well. My first autoguiding setup was an orion Magnificent Mini Autoguider. It’s a 50 mm guide scope/ SSAG package that might be a bit pricey, but works very well and was really easy for me to setup.
I’ve had it for five years and it works very well with my 102mm refractor.
I have heard a lot about the ASIAir, but I am a N.I.N.A. fan. The Orion should work fine with the ASIAir.
If your AVX acts up when imaging unguided, the guider should help a lot. Also, if you plan to get deeper into AP, guiding will be a must.
Good Luck!
Jim
TurtleCat avatar
Jim
I will test it.
What do you think?
The Orion guide scope is fine but if you plan to use an ASIAIR then the Orion camera (which is very old and obsolete IMO) isn’t compatible. You might consider one of the ASI mini cameras instead. There are several options available. For good or bad, with an ASIAIR you need to stay with ZWO products.
Oscar H. avatar
@TurtleCat
I will get a zwo asi120mm mono guiding camera instead, with an asiair mini.
@Juno16
I will read the agena article.
Thank you.
How bad is over-sampling?
Matching pixel-size to focal length sounds great, but in reality most modern CMOS cameras have pixels of 3.8 micron (few exceptions). So most of us with a long focal-length of around 2m and more (SCT's, RC's, CDK's etc.) will have highly ...
Discusses pixel-size matching and CMOS camera considerations relevant to EOS R5.
Sep 19, 2024
Seeing vs focal lenght
Hi all, greetings from nothern Italy, first post overhere! there is a concept that based only on my experience, i would want to ask you all if im right or am i missing something? referred exclusively to AP: "getting a bigger focal lenght scope (...
Explores focal length effects on image quality, directly relevant to 1000mm setup.
Aug 27, 2024
On an iOptron GEM28, for use with planetary/lunar photography what would be the largest scope you would put on it?
I have an iOptron GEM28 which I use with a small 5" newtonian and imaging train (ASI533 camera, filter wheel, OAG, guide camera) and this is working fine for astrophotography. I can guide around 0.50" RMS constantly and 600-second exposures...
Addresses mount capabilities with long focal lengths and autoguiding setup for imaging.
Sep 5, 2024
