Have I got this right regarding imaging, seeing and resolution?
Piers PalmerTim HawkesWillem Jan DrijfhoutDark Matters Astrophotographyandrea tasselli
36 replies1.8k views
Piers Palmer avatar
Galaxy season is just around the corner. I would really love to be able to capture some of these (visually) tiny little objects but I've been reading about image scale and seeing and resolution and all that sort of thing.
I have an ASI2600MC Pro which has 3.76µm pixels. If I assume my seeing will, at the very best, be 1", then I arrive at a maximum focal length of around 800mm…conveniently the same as my R200SS . However, that's not a lot when it comes to galaxies, but if I were to get something like an Edge 800, then using my camera, I would get aound 0.4"/pixel, or way more than my seeing could offer me.
Is my simplistic reasoning correct?
If so, am I right in thinking the only way to get a larger image scale without blurring the detail would be to get a longer focal length telescope AND a camera with larger pixels?
I know it's easy to worry about oversampling and undersampling too much, but I don't have enough money to waste on stuff that won't actually make anything better!
Well Written Insightful Engaging
Gernot Schreider avatar
Hi Piers,
I found this article most helpful for deciding which camera to match to my optics.
Matching Your Camera to Your Optics - Astronomy & Scientific Imaging Solutions (diffractionlimited.com) .
Cheers
Gernot
Piers Palmer avatar
Perfect - thank you Gernot!
If your seeing is genuinely 1" (which is really excellent) then 0.4"/px sampling is not a bad place to be.   In general you would sample at 2x to 3x seeing to get the most out of your resolution.  This does require excellent tracking as well.   If you are not able to track to the image scale of your system, it will blur your images similarly to that of degrading seeing.
The benefit of tiny pixels is that you can produce very high resolution images with modest focal lengths.  With a larger aperture and longer focal length your system will be more efficient and resolving power higher, but there are more challenges with longer focal lengths to consider.
I'm using the same pixel size as you.  I imaged a ton with an Edge 925 as well as my 130mm refractor and compared the data.  My FWHM was identical for both setups.  While the Edge could produce an image with less integration time, I ultimately decided that for my skies (average or worse seeing) that it would just be more convenient to use the refractor only.
Something else to keep in mind is that you dont need a larger pixel camera with a long scope.  These 3.76um sony chips are the kings for astroimaging with any focal length.  You can always bin the camera (for smaller files) or just downsample in post processing if you are too oversampled.  The low noise and well behaved data from these cameras makes them an excellent choice for any focal length scope.  If you get an Edge and a large pixel CCD you might need to take 20 or 30 minute exposures to clear the noise floor.  With modern CMOS you could still get away with your 5 or 10 minute subs.
My $.02.
Piers Palmer avatar
Thanks Chris - what a great reply...appreciated.
My seeing almost certainly won't be 1"; I was postulating that as a theoretical maximum. I'm generally bang underneath the jet stream. I've never actually tried to assess it subjectively, Maybe one night I will!
I'm not hankering after a SCT. I already have my f/4 Newtonian which I've used happily, considering the challenges fast newts bring with them. I'm staring to get my head round binning now I'm looking into image scale etc, and that does seem a more sensible route, particularly if, as you say, 3.76um camera are some sort of sweet spot for astrophotography.
I think what I should have done, instead of getting my Vixen SD81, was perhaps have gone for a SD102 or even 115 (my mount would cope easily with either), to complement my Redcat51 and maybe forgo the Newtonian altogether.
At least I know my camera isn't ever going to be the limiting factor!
Respectful Supportive
Piers Palmer:
Just to clarify, it's not really the pixel size that makes the current generation of astrocameras the "sweet spot" choice.  These cameras are great because the noise is low, no amp glow, clean noise profile, etc... they also happen to have a pixel size that is ideal for wide-field imaging and can be used comfortably with long focal length as well.  Unlike CCD there is really not much benefit to binning in camera, so you can image at full resolution and just downsample in post processing to effectively improve your SNR and for display/viewing purposes.
800mm focal length and IMX571 is a good combo for imaging galaxies.  You can crop to tighten up the view and if you collect enough (well dithered) data you can get a resolution benefit by drizzling.  Also with new tools like BlurX you can eek out even more detail from your image.
Piers Palmer avatar
Got you - yes, that makes perfect sense, although I had to check what sensor my camera had!
My current SD81 has a native focal length of 625mm so that's probably a bit too short, but because I already have the Vixen flattener and reducer, I could "upgrade" to something longer without the need for any additional accessories. I shall have a play in Telescopius and browse the galleries here while in the pub tonight!
John Hayes avatar
You might also watch this video (or just view the slides):  https://www.advancedimagingconference.com/articles/secrets-long-focal-length-imaging-john-hayes
AIC is now free to join so this is available to everyone.
800 is a bit too short for the average galaxy and 8" on the smallish size as well. I'd be happy to sit at around 3 arcsec as average integrated seeing from my location and I have never experienced anything better than 1.5 arcsec even from Chile. Oversampling is BAD idea and even binning with CMOS put you back where you were with the CCDs (but without the capability of actually binning the pixels in-situ). Unfortunately there is very little else out there with anything more than 3.76um pixels.
Tim Hawkes avatar
Just a bit on what I have experienced so far imaging galaxies.   I have found that what you can do depends an awful  lot on conditions and also very much upon which particular aspect of of galaxy imaging that you wish to prioritise.   Go for deep detail in the brighter core or go for capturing the fainter parts?  If you are at the stage of making purchasing decisions it might be worth  looking into the crystal ball a bit on that and also consider what best fits your conditions.
So here is my example…
Under the best seeing conditions here in the UK Thames Valley for example I have captured  (linear) integrated images at as low as 1.9 arc sec  using a 200mm telescope and maybe 1.7 arc sec using a 300 mm telescope  - so the actual sky FWHM must have been a bit lower than that - at least transiently for the period of many of the short (3s) frames.
However these (relatively) good seeing conditions often coincided with poor transparency and vice versa.  So  good conditions for trying to bring out fine detail in the galaxy core – but not so good  for trying to capture the whole extent and faint outer reaches of galaxies.
For broadband objects like galaxies filters don't help a lot and sky darkness is critical for seeing the outer reaches and fainter parts.  I live at a Bortle6 site so to capture frames that add information about the fainter parts I travel to a darker site – at least Bortle 4  or better to achieve 10 fold increase in SNR or more.
But just back to resolution it is possible to beat the seeing to a certain extent and gain more resolution than the seeing should allow - (e.g in some images I estimate being down to ~ 1.2 arcsec) - and particularly in the brighter regions -  by using a combination of 'semi' lucky imaging  and image deconvolution (or now BlurXterminator) .  These approaches work quite well on galaxies -   but only really on detailing the core regions and the brighter galaxies.  It is an aspect of galaxy imaging that I enjoy and that - to a certain extent - local conditions constrain me to.
In case you didn't happen to know (sorry if this redundant info)  - deep sky (so-called) lucky imaging involves stacking many short frames (~ 3-5s)  rather than using the normal longer exposure times.  Part of the power lies in selection  – many of the frames are rejected - so the ones you choose to stack are brighter and have lower FWHMs.  Particularly combined with deconvolution it is one route to getting a sharper image if you don't happen to live where seeing is good most of the time.  However because the frames are necessarily so short  SNR is a real problem - hence the focus on bright objects and brighter parts of objects.   For this approach therefore it really also helps to have a bigger D as well as a longer f and reasonable speed as well -  so ~ 10 inch Newtonians at F 4-5 etc.   The other aspect is deconvolution  for which it actually helps to oversample somewhat   – i.e.  if you want to end up sharpening  to an effective image resolution of 1.5 arcsec  or better then - to sample sufficiently -  would require an image scale of < 0.75 arcsec/ pixel.
To be honest though if I'd have lived in the Californian mountains and had 1 arcsec seeing then I wouldn't have bothered with lucky imaging at all probably….
I only mention the above - which may be a sidetrack in many ways - because if your skies and conditions did a resemble mine then it could impact your choice of equipment for galaxy imaging down the road.   So for the particular approach above I'd go  for a 10 or 12 inch scope,  f 1000-1200  and look to at least have the facility to  sample at 0.5 arcsec/ pixel   (you can always bin when it is not needed).
Tim
John Hayes:
Just finished the presentation, thanks for sharing the link. A very comprehensive review and study of imaging that everyone should view when they have the time (little over an hour).  I'll be downloading the PDF as well, since some of the charts, Pixel Math, and other nuggets will be good to keep handy.
Sky Wave is a great piece of software that I plan to run against the big scope that is heading to NM soon.
Bill
Piers Palmer avatar
John Hayes:
Thanks John. I’ve just signed up and will Take a good look!
Piers Palmer avatar
Tim
My skies will be worse than yours in many respects…I’m in Cumbria. Bortle 3, but Cumbria!
I’m definitely more about the fainter stuff and probably seeing galaxies in context, so perhaps focal length isn’t as important?
When you say 200mm and 300mm scopes, you’re referring to aperture I assume? My R200SS is fine on my mount so perhaps I should really try to nail down collimating and give it another go.
I’d forgotten about lucky imaging and haven’t ever given it a try so that’s worth a stab too.
Piers Palmer:
John Hayes:
Definitely do, it is very good and from some perspectives should be highly encouraged content for all imagers to consume.
I specifically want to call out a few sections of the content (not in order):
  • Slides 42-44. Love these graphs, as they can really help one to see how a system will work given different seeing conditions. For example, I will be deploying a 14" CDK with a 3.76um pixel camera (pretty common pixel size these days). In 0.5"-1" seeing, this combination will produce great results at bin 1x1. As the seeing shifts to 1.5"-2" that is when I should consider binning the data - which can be done nicely in post-processing.
  • Speaking of Binning in Post, if you continue through the presentation, you will hit Slide 50. At the bottom of the slide there is some Pixel Math included by John that can be used to perform binning in post processing. Of course, there is also the Integer Resample process in PixInsight as well. Be sure to review all of the content here (and not just the math) as John gives some good insight (as always).
  • Slide 18. john talks about optimal spacing for sensors here, and the real-world experience I have had matches what John has stated here. The larger the sensor you are working with, the more delicate those space adjustment can be to get things just right. I was surprised a little to hear that that C14 at F11 would have tolerances less than 100 microns, but it goes to show that for big chips one needs to be prepared to put the work in to improve image quality.
Of course, there is a lot more in this presentation than just these bits. The Seven Keys to Success he calls out are all very important and can help one step up their game immensely.
Tim Hawkes avatar
Piers Palmer:
Tim
Well after it stops raining those Bortle 3 skies will be nice and transparent -- and lucky imaging well worth trying to combat seeing because at Bortle 3 your SNR is going to immediately be 15 fold better than mine  which will make the short frames less of a problem- so indeed you already have a very good scope for the job sampling at just under 1 arcsec. .... could even try a small cheap planetary camera (no cooling needed at 3s) with 2.15 uM pixels to get luminance sampling at 0.7 arcsec or so.  Many galaxies are so small that big fields aren't needed  and small sized frames is important so that the amount of data doesn't get too huge.
Helpful Insightful
Piers Palmer avatar
My guide camera is a 290mm mini. Even something as humble as that?!
All this talk of lucky imaging with galaxies leaves me rather cold. It simply doesn't work. You'd need small angular field, very bright subjects and large, fast apertures. Else, you'd need very good seeing. And I know because I did it when nobody was doing it (but in my case were the handful of bright PNs). Now you can get much better results but the recipe is still the same. And good seeing, as an average. At least for broadband subjects.
All this talk of lucky imaging with galaxies leaves me rather cold. It simply doesn't work. You'd need small angular field, very bright subjects and large, fast apertures. Else, you'd need very good seeing. And I know because I did it when nobody was doing it (but in my case were the handful of bright PNs). Now you can much better results but the recipe is still the same. And good seeing, as an average. At least for broadband subjects.
I tend to avoid the lucky imaging topics as it's not really something that interests me, and the results I've seen that were very good were basically all of the same very bright galaxies. Which isn't to say that it's bad or anything, my interests lie in the deeper integrations, fainter objects, and even wider field Galaxy Clusters.
Tim Hawkes avatar
Piers Palmer:
I don't know to be honest since I have not tried with it -  maybe the field size would just be too small  and difficult to guide accurately enough?  I have actually been using an ASI 1294 MM  in unbinned mode with pixels at 2.15 uM and then just selecting small frame modes ... normally about 1600 x 1200 pixels resulting in an image scale of 0.4 to 0.5 arcsec/ pixel.  That provides luminance that can then be added to OSC images to sharpen them up.  I already owned the expensive camera but noted  really the same could have been acheived with something much cheaper.
Anyway no harm in having a go... of course the real trick is waiting for the right sort of conditions but I do think that your dark skies might prove quite a bonus.
Tim
Freestar8n avatar
For people interested in max detail there is no reason not to use very small pixels - for reasons that may not be obvious at first, but should make sense once it is explained.
Typical discussions of "pixel matching" to seeing only refer to a single exposure, and they ignore what happens under the covers when you align and stack.  This is where it helps actually to write code that does this - so the details are evident - but it is easy to understand.  When you align and stack, the pixels don't just stack on top of each other.  They are all being shifted and mapped into the destination image - and if the destination image has the same size pixels - it means each pixel will tend to contribute its info to a small tile of 4 pixels.  And that has a blurring effect.
There is no way around this and it happening every time you align and stack - but people don't tend to be aware of it because they don't "see" it happening directly.  But if you take a given exposure and try to map it into an image with a shift in x, y a fraction of a pixel - the result will be smoother and softer.  *That* soft image is the one used in the stack - not the original sharp one to which people apply Nyquist.
The key thing is that this blurring happens *on the scale of the pixels* - which means that smaller pixels will result in less blurring.
As for applying Nyquist here - it doesn't apply directly because the requirements of the Nyquist theorem are not met in the first place.  But even if you apply it as a rule of thumb and say "pixels should be 1/3 the fwhm" or something - you would be better applying an additional factor of 2 so it is 1/6 fwhm or so.  The thing is - smaller will always have benefit because - again - *the blurring happens on the scale of the pixels*.  Smaller pixels = less blurring = smaller realized fwhm.
For people who don't hope for better than 2.0" fwhm and end up using 0.5" pixels - they will likely get their wish and never do much better than that.  But I think everyone should aim for at least 1.5" fwhm - if they do in fact want max detail.  I haven't imaged from Umbria, but I did spend a few years in Dublin, Ireland and despite the horrible conditions there, I think 1.5" was possible on at least some nights, and pixels around 0.3" would be good for that.
In my case I use EdgeHD11 at f/10 with 3.78um pixels or 0.28" per pixel - and I often get fwhm's in the low 1" range.  But it does require good collimation, focus, and guiding.
There is always the issue of possibly more noise with smaller pixels and no significant gain if the seeing is poor - but in those cases you can bin or smooth the final result.  The key is that the small pixels minimize the blurring that happens during stacking - so you still benefit.  This is in contrast to having large pixels and not even realizing that you could have done much better on a given night.
But this is only relevant for people who do want max detail.  For wide field images where 2.5" or so fwhm is fine, there is no need to go below 0.5" or so pixels.  But there are lots of interesting and tiny objects up there that are rarely imaged - so it's a rich subject for study - with small pixels.
Frank
Piers Palmer avatar
Thanks Frank…a lot to digest there!
Can I ask a very beginnery question?! When I click the “detect star” button on my ASI Air and it gives me numbers for certain stars, are they the figures being discussed?
Tim Hawkes avatar
Inter alia -- that is a very good point.  (A very dull thing to do I know) but in PI you can watch the error numbers go by as the frames get aligned.  I agree also about aiming for better resolution and taking the pixel size down which also matters if you eventually want to apply deconvolution.  FWHM ~ 1.5 or so is occasionally  possible  even in the Atlantic climate of Britain and Ireland.
Freestar8n avatar
Piers Palmer:
Hi-
I don't know what ASIAir tells you but the main ways to measure star size are fwhm and either HFR or HFD - and all these things can be measured either in arc-sec or pixels.  If you are striving for detail then it helps to keep track of star sizes in arc-sec because it's an absolute number that tells you how well things are working.  I recommend fwhm in arc-sec if possible.   If things are working well you should have some nights with large fwhm and others with small - indicating you really are seeing limited.
If you do want detail in small objects then I expect 8" f/10 would do better than your f/4, and I wouldn't worry about oversampling.  The downsides are larger files and subexposures that look noisy and not very deep - but you can always resample at the last stage of processing to trade off detail for noise level.
And you would need to use OAG if you are striving for max detail.  Switching from f/4 with guidescope (I assume you use guidescope?) to f/10 with OAG is a big step in complexity - but it should have benefit if you want max detail in small objects.
Frank
That isn't exactly true.
Piers Palmer avatar
Frank
I've guided with both guide-scopes and using an OAG. I've currently gone back to a guide-scope because I can place it in front of the mount and it helps counter-balance the added weight of the 2600MC Pro camera compared to my previous 533MC Pro. Also, at only 490mm focal length, I didn't notice OAG gave me any benefit, and actually made things a bit more complicated when it came to focusing if I changed filters (I found I had to put the OAG in front of the filter to get enough stars).
This is how my current setup looks.
So in terms of using an OAG, I'm fine with that.
I can see something like an Edge 800HD would be ideal, but I did, briefly, have a cheap RC6 and really hated the images I got through it. I've always put that down to its slow focal ratio but I think it was probably more down to using a guidescope at a long focal length and having rubbish collimation. I've been reading up on focal ratios and the role of reducers (my Vixen above normally has a x0.79 reducer in it to bring it to f/6) and people like Olly Penrice suggest they're not quite the asset YouTube would have you think. So imaging at native f/10 might be absolutely fine?
The bottom line for me is, it's the little, obscure, tiny things up there that really interest me. Yes, I love getting a nice big broad colourful cloudy patch of sky, but there are only so many of those to shoot. My favourite ever shot was one I took of Markarian's Chain. It's nothing special, but the journey my brain went on capturing that was fantastic. I'd happily spend my evenings looking for a faint blob which meant I'd caught something very very distant and often overlooked. I don't think my current equipment really allows for that.
Newtonian/Ritchey-Chretien Telescope For Astrophotography
I've been using a William Optics Zenithstar 81 for almost 12 months now and find it great for capturing nebula, however, I'm looking to purchase something cheap and cheerful which I can switch my filter wheel and camera across to when capturi...
Galaxy imaging resolution and sampling relevant to telescope selection.
Feb 26, 2021
Anyone make the move from a recent CMOS to CCD?
Hi there, I've been using a range of CMOS cameras over the last 18months or so for deep sky imaging, more recently moving into mono narrowband imaging with the ASI294mm and more recently the ASI2600mm. I've had some pleasing results, but my s...
Relevant - discusses seeing, resolution, and camera pixel size optimization.
Sep 1, 2021
Pixel Scale Advice Appreciated
Hello! I've found conflicting information on what's considered oversampling, good sampling, and undersampling. Mainly for oversampling, Astronomy Tools says that between 1.0"- 2.0"/pixel is good, under 1.0" is oversampling, and...
Discusses imaging resolution and sampling considerations for astrophotography.
Jan 20, 2021
