Apertura 60EDR vs 72EDR with DSLR
iOptron Skyguider Pro 3 replies63 views
UKFanRN1973 avatar
Which would be the better option to use with my Skyguider Pro and my Canon T7i DSLR?
cosmicjavelina avatar
Well, the rule of thumb is to keep the weight of your camera, scope, and guiding gear below half of the mount's rated weight capacity.  So the 72EDR will probably put you over that.  Having said that, I know that some folks exceed that rule of thumb and still get good results.   There isn't a huge difference in terms of focal length on the two scopes so your FOV will probably be very similar.  I use a 400mm prime telephoto lens with a canon 80D (it has the same APS-C size sensor as your T7i) and, for reference, the Andromeda Galaxy nearly fills the frame from corner to corner.  So I would expect the 60EDR to give you a slightly wider FOV and the 72EDR to be slightly tighter.  That is assuming you use a non-reducing flattener with the scope.  One suggestion, if you use Stellarium, you can plug in your camera and scope specs and preview how various targets will look.  I hope that is helpful to you.  Happy New Year, and clear skies!
Bill
UKFanRN1973 avatar
Thanks. I have the Stellarium app on my iPhone, can I do that there?
Don't know.  I use it on a laptop.  there's an ocular view plugin that shows the FOV of your selected camera and scope combination.
Does Canon EOS 2000D Have good image quality in Astrophotography?
#astrophotography Hello And Welcome. I'm new at photography and I'm partly interested in astrophotography. The thing I wanna ask is that in about to invest in a Canon camera which is DSLR. And I'm wanna ask that is the Canon EOS 2000d has...
Canon T7i is relevant; discusses astrophotography with similar DSLR equipment.
Jul 6, 2024
I need help with starting equipment
Hello I want to ask a question about what equipment to get for deepsky objects. I was reading here and there for cheap starting equipment. I was deciding between 2 DSLR's : Canon 2000D and Canon 600D and i want to ask which one is better and if t...
Addresses starting equipment selection for astrophotography with budget considerations.
Jul 22, 2024
