Issues with 533MC Pro image calibration and stacking artifacts
1 reply220 views
Vince Tambellini avatar
Hello, I am new to deep sky processing, and have some odd blocks appearing in my image.
This is a capture of M45, about ~1 hour of data with 5 min exposures and with a few of the images drizzled. I stacked using deep sky stacker on the recommended settings, and am using PixInsight. Data collected on an ASIair plus.  This image does not have calibration files, as those are also causing me more issues than not, at the moment.
When zooming in, I can see these strange looking blocks, after splitting the colors, linear fit and channel combination.
Would appreciate any ideas here. Thanks!
I added drizzle 2x to the imgaes, and it looks like it fixed the issue!
DSS help
I use DSS for calibrating and stacking images, in some images I noticed poor stacking (one corner where the coma is more evident). Any idea how to improve the quality of stacking in DSS? Any special setting?
Discusses stacking artifacts and calibration issues relevant to DSS stacking problems.
Sep 9, 2021
Trouble with Deep Sky Stacker applying flats correctly
I'm having trouble with stacking photos lately and not sure what changed. I'm seeing dust mote artifacts in stacked & calibrated images that shouldn't be there. Below is an image straight out of DSS. No further editing, STF applied. Y...
Calibration files causing artifacts; flats troubleshooting relevant to stacking issues.
Dec 9, 2024
Drizzle integration issue in PixInsight after two sets of images with different resolution have been previously correctly integrated
Hi everyone, today I’m presenting an issue I’ve encountered while trying to integrate two sets of images with different resolutions and original sampling in PixInsight: one taken with an ASI533MC PRO + 115/800 telescope and the other with a Canon 90D...
Drizzle integration problems in PixInsight directly match author's drizzling mention.
Dec 6, 2024
Artefacts in registered images....what am I missing????
Hi All I am imaging a dusty region, and when stacking, I can see that my flats have not correctly removed a particular artefact. Any input on what I might be missing here?? I cannot understand what I am not doing correctly to prevent this annoying ar...
Stacking artifacts and flat calibration issues similar to author's block artifacts.
Nov 28, 2024
