[PixInsight] How to prevent Flat overcorrection?
5 replies604 views
distantnova avatar
I'm not sure why, but my light frames are getting "overcorrected" by the Flat calibration process of the WeightedBatchPreProcessing script. Does anyone know why this happens and how I can prevent this? Is this maybe due to the large dark regions at the corners?
dkamen avatar
When flats aren't working, it is either a problem with darks/dark flats (e.g. wrong gain/offset) or a general problem with your flat field (dew, stray lights, reflections).
Well Written Concise
I recently helped someone with a similar issue on another thread.  It turned out that the flats were calibrated with frames taken with a different driver than the light frames.  Make sure you are using the same driver, gain, offset, etc… for the calibration (bias) frames used for preparing your master flat.
Well Written Helpful Concise
Mike Cranfield avatar
It may help if we could see one of your flat frames?  From the image you have posted I am thinking perhaps dew on one of the optical surfaces when you took the flats maybe.
distantnova avatar
Turns out I was missing Bias and Dark frames - I took them with MaximDL instead of NINA as I did for the Flats and Light frames, but they had a different size (included the overscan areas), so the Lights (and Flats) were not calibrated with them. Now that I have cropped them, my fields are flat again smile
That would do it.  Most of these large scale flat correction issues are due to mismatches with calibration frames.  Glad you figured it out.
Well Written Supportive
Can We Use Ha Scripts Or Hubble Palette Script on Light Frames?
Hello and welcome! I'd like to ask if anyone has experience using light frames with scripts other than the without Darks, Flats, and Biases script. I'm curious if we can use any enhancing scripts to modify our RGB-based images. Is it possible...
Discusses light frame processing with calibration scripts and frame types.
Sep 23, 2024
can't seem to take proper flats with asi 294mm
hello, so recently I made a big upgrade and bought a asi 294mm pro with chroma 1,25" filters (LRGBSiiHaOiii), and also I control everything from the eagle 5 s. this is my first time imaging with a mono camera, and also been using Nina for a few ...
Addresses flat calibration issues with specific camera and filtering setup.
Jul 25, 2024
Is It Possible To Take Calibration Frames With Seastar?
Hello and welcome. I'd like to ask everyone who is using Seastar or knows some method if it's possible to do with Seastar? To take any Calibration frames besides lights. Like darks, flats and biases. I'm just curious that is why I'm a...
Covers calibration frame acquisition methods and technical considerations.
Sep 20, 2024
Help with Flats Overcorrecting, Please
Hi, So for the past few months I've been experiencing an issue where my flats are now overcorrecting my lights. When the issue started, I had not made any changes to how I acquired or processed the flats (or the rest of the data). Since then, how...
Specifically addresses flat overcorrection problem in PixInsight processing.
Apr 29, 2021
