DARKS, FLATS AND BIAS REVISITED
10 replies686 views
Alicia Rossiter avatar
Hello everyone. I would like to seek feedback on best practices for darks and flats
Currently I do: 20 darks, 40 flats, 40 dark flats and I don't do bias
What is the right balance?.  Does the number of light frames dictates the number of darks and flats?.
Does it make sense to do bias o top of flats and dark flats?.
How often should the library of darks be updated?.
Thank you for your inputs and clear skies.
Alicia
Jonny Bravo avatar
More is better… to a point. I think James Lamb did a video on YouTube with some statistics…
Anyway, I typically don't take more than 30. I take darks, flats and flat darks. I do not take bias frames because of my camera (294MM Pro).
I keep my darks for months. No set rule for me.
Alicia Rossiter:
Alicia
Question 1: There is no right balance because there isn't  anything to be balanced
Question 2: No
Question 3: No
Question 4: When there is a significant change in the dark current or every 6/12 months or thereabout
Cheerio
Arun H avatar
Alicia:
There was a long thead about this:
https://www.astrobin.com/forum/c/astrophotography/deep-sky/lets-discuss-about-dark-bias-dark-flats/?page=1
Ignore every other post in it, simply read John Hayes's post.
16 darks is more than enough for most people in most circumstances. Same with flats. There is a mathematical logic to this. Taking 40 wont hurt, but is a waste of time. And you should be taking dark flats (or bias if you trust your camera to give you a reliable bias).
Andy Wray avatar
FWIW:  I take 20x darks, 20 x flats and 20 x dark flats for each filter and that seems to do the job.  I don't take bias frames anymore.
Well written Concise
Thanks to all who shared their routine
Based on everything I have read, I think I will continue with the 20 darks + the 30 or sometimes 40 flats and dark flats. It has worked for me.
Clear skies
Bill Nichols avatar
Alicia:
Attached is a link to a presentation, "Basics of Statistics for Astro Imaging" on the Astro Imagining Channel  by John Hayes. It's long and detail, but he uses statistics to determine the number of calibration frames. Basically, he states that for every light frame you need 5 calibration frames, for example if you take 40 lights you need 200 calibration frames. There's a lot of good stuff in his presentation and it's very well done.
https://www.youtube.com/watch?v=T_k9B01AeFM
Clear skies,
Bill
Karl Theberge avatar
Well, I had a chat with DarkArchon and also the guy who created NINA and they plainly convinced to stop using darks altogether.
you should maybe give it a shot, your camera is not supposed to produce amp glow so.
Bias and Flat should be enough and the good thing is you dont need a lot of time to take them.
Last night I did 2 set of 25 flats and a set of 100 bias.  Took me less than 5 min.
Good point about the amp glow. True, the 2600 MCPro has zero amp glow, however my 183MC Pro has awful amp glow, and sometimes it does not go away completely even with the darks. why is the added value of the bias ?. Thanks a lot for the info!.
Jonny Bravo avatar
You use the biases to calibrate the flats. If you look at the typical (simplified) math done for calibration it looks like this:
(light - dark) / (flat - bias)
The advocates for the "don't take darks" method argue that the IMX571 sensor is so clean, calibrating with darks is not necessary and can actually be detrimental to your image. They will use other techniques like cosmetic correction and/or dithering during acquisition to get rid of the hot pixels that would have been removed by using a master dark. A benefit of not having to take/use darks is as @Karl Theberge wrote: calibration frames require minimal time. Granted, I have quite a few master darks I've taken at various gains/offsets/temperatures/bins. After all, there are far more hours I am not imaging than hours I am .
My suggestion? Try calibrating your lights using darks, flats and biases... then calibrating your lights using only flats and biases. See the differences for yourself and determine what works best for you.
Jonny Bravo:
I tend to agree with the try and use what is best for you.  At the end of the day, if the result is good, and you get same or better using different tool, why not.
Is It Possible To Take Calibration Frames With Seastar?
Hello and welcome. I'd like to ask everyone who is using Seastar or knows some method if it's possible to do with Seastar? To take any Calibration frames besides lights. Like darks, flats and biases. I'm just curious that is why I'm a...
Discusses calibration frames including darks and flats relevant to author's question.
Sep 20, 2024
The ultimate weapon to deband CMOS sensors
In this post I present an easy to implement and extremely effective method to remove vertical (or horizontal) patterns, inherent to many modern CMOS sensors. The processing is done using PixInsight, and makes use of masking in the Fourier domain. Fir...
Addresses CMOS sensor issues that calibration frames like darks help correct.
Sep 21, 2024
